i´am the best
Posted by: klotis on 10 May 2010
seems like this forum is about who has the best rig.....
Posted on: 10 May 2010 by Christopher_M
Well I've just checked your profile Klotis and your kit's better than mine
Regards, Chris
Regards, Chris
Posted on: 10 May 2010 by js
Every forum is about 'me' and bad spelling/grammar so you've actually made 2 good points.
Posted on: 10 May 2010 by shoot6x7
Nah, mine is :-D
Posted on: 10 May 2010 by perflemming
Well, at least - you have some speakers
Posted on: 10 May 2010 by winkyincanada
quote:Originally posted by Christopher_M:
Well I've just checked your profile Klotis and your kit's better than mine![]()
Regards, Chris
Better than mine, too. I guess you win the interwebs today.
Posted on: 10 May 2010 by mrflange
nO iTS Knotquote:Originally posted by js:
Every forum is about 'me' and bad spelling/grammar so you've actually made 2 good points.![]()
Posted on: 10 May 2010 by MilesSmiles
Usually it's about who has the biggest ...
Damn, and I was doing well.
Posted on: 10 May 2010 by BigH47
Mine's better than his!
Posted on: 10 May 2010 by hungryhalibut
Actually, the forum has less willy waving than it used to in my view. All posters are generally treated with respect regardless of their systems, on the assumption that what they say is sensible in the first place.
Nigel
Nigel
Posted on: 10 May 2010 by Willy
Yes I have lost a bit of weight.
Willy.
Willy.
Nice one, Willy! I wonder if I had suggested that there had been less arse scratching recently whether Arse would make an appearance?
Nigel
Nigel
Not sure we should be encouraging Arse to make an appearance.
Willy.
Willy.
Posted on: 10 May 2010 by 151
how do you come to that conclusion? i find the exact opposite.quote:Originally posted by klotis:
Posted on: 10 May 2010 by King Size
If anything its more about telling people they have to spend more money on their own gear because it won't sound very good without a DAC/Flatcap/Hicap/Supercap/Powerline/Hiline/Fraim/Aro/Superline/dedicated mains spur/USB stick....
Posted on: 10 May 2010 by mongo
quote:Originally posted by 151:how do you come to that conclusion? i find the exact opposite.quote:Originally posted by klotis:
Me niether, very little one-up-manship here, if any at all.
Seems an odd statement.
Troll anyone?
Posted on: 10 May 2010 by u5227470736789439
Certainly, unless you are very sure of what you want and require of replay then reading in the Hifi Corner can easily tempt extra and unplanned spending!
It can also breed dissatisfaction with a perfectly fine replay set, initially chosen as being just that. This can have insidious consequences for the unwary.
The trouble is really that people are not always sure what they want, so even the advice to audition is not always helpful, though it is pretty much the only sensible advice that can be given in general.
I sometimes think that enjoying a fine examples of manufacturing craftsmanship such as top-class Hifi can be satisfying of itself, and suspect that there is no more harm in this than being a music enthusiast with large collection of recordings, so long as people are honest with themselves and others about what the real motivation is for buying and enjoying the ownership of such items really is.
Then the keeping up with the Jones's phenomenon would not be quite such a pressure on those who struggle to compete with the most well healed!
ATB from George
ATB from George
Posted on: 11 May 2010 by DAVOhorn
I do not and never have owned NAIM gear.
Where does my equipment stack up in the heirarchy?
Concerned and worried that i will not be allowed to compete in this appendage competition.
I do know mine goes louder though!!!!
105dbw corner horns YEEEHHAAAAA
sorry i will behave
sorry i will behave
Posted on: 11 May 2010 by 151
you cannot enter the competition unless you have a 552 and live in a big house.quote:Originally posted by DAVOhorn:
Posted on: 11 May 2010 by mongo
quote:Originally posted by 151:you cannot enter the competition unless you have a 552.quote:Originally posted by DAVOhorn:
CRAP.quote:Originally posted by King Size:
Posted on: 11 May 2010 by js
It can be off putting if pushed but there's a difference between good and better. Often there's also a negative view that forces the issue to extremes. Perfect as is is just as over the top. Plenty good in general and for my needs would be more appropriate. Just as the OP describes the bigger than scenario, there is a 'nothing is significantly better than mine' one that is also common to message boards.quote:Originally posted by King Size:
Posted on: 11 May 2010 by King Size
quote:Originally posted by 151:CRAP.quote:Originally posted by King Size:
We disagree then.
quote:Originally posted by js:It can be off putting if pushed but there's a difference between good and better. Often there's also a negative view that forces the issue to extremes. Perfect as is is just as over the top. Plenty good in general and for my needs would be more appropriate. Just as the OP describes the bigger than scenario, there is a 'nothing is significantly better than mine' one that is also common to message boards.quote:Originally posted by King Size:
My post was merely intended to disagree with the OP that this site is merely a 'willy waving' competition. However there are a number of members who are given to hyperbole when it comes to upgrade options (for eg. 'CDX2 sounds broken without it' and other such assertions)
@151 - the above comments are far from imagined
Posted on: 11 May 2010 by Huwge
I'm Spartacus!
