what will disolve silicone?
Posted by: AL4N on 28 January 2007
does anyone know if there is a substance that will disolve SILICONE?
Posted on: 28 January 2007 by Beano
B&Q or the builders merchants will sell a chemical to dissolve it, however, if you want to remove an object which is stuck down with the stuff, try sliding some fine fishing line, a guitar string, or dental floss under the base of the object.
Dow Corning is a good brand to look for!
Beano
Beano
Posted on: 28 January 2007 by AL4N
thank you, so obvious, yet i didn't see it
Posted on: 28 January 2007 by manicatel
Screwfix sell a silicone sealant remover
p138 of the current catalogue, or part number17175-83, £2.39 for 100ml, or they also do a stuff made by Elch, 300ml for £7.99.
It does tend to make a bit of a mess, (or I did when I used it), & I resorted to a bit of patience & a sharp scalpel/stanley blade.
matt
matt
cheer's, i am trying to lift a sink from a tiled floor, i hade no idea it would stick quite so good.
Posted on: 28 January 2007 by Right Wing
C4 should do the trick
Posted on: 28 January 2007 by Willy
quote:Originally posted by Right Wing:quote:Originally posted by AL4N:
Suspect Al4n doesn't want to lift it quite that high.
Willy.
Posted on: 29 January 2007 by AL4N
quote:Originally posted by Willy:quote:Originally posted by Right Wing:quote:Originally posted by AL4N:
Willy.
quite.
Posted on: 29 January 2007 by ewemon
Don't forget to clean the surface afterwards with either White Spirit or Turps.
Posted on: 29 January 2007 by Skip
From Tarptent.com FAQ.
"An inexpensive product that works well is GE Silicone II clear sealer/glue. It is available as a squeeze tube in most US hardware stores or in the Tarptent Store. Set up the tent ouside in a in a well-ventilated location. Mix about a tablespoon of silicone with a couple of tablespoons of mineral spirits(paint thinner) and then apply the solution with a small foam brush. Add more mineral spirits if the solution gets too thick. Avoid skin contact and breathing fumes."
Good luck.
Good luck.
Posted on: 29 January 2007 by Ridzwan
C4?....hmmm, you can try semtex.
Posted on: 30 January 2007 by Chillkram
Posted on: 31 January 2007 by Alexander
quote:Originally posted by Chillkram:
Space flight?
Surely that's a scheme to get women to upgrade their mammarian protruberances to spaceproof status? Is there such a thing as upgradeitis in that uh, there?
