looking for an amp
Posted by: slippery on 06 June 2003
hi everybody:
I am looking gor a naim integrated or pre+power capable of moving properly my Proac“s R1 Sc.
Any suggestion?
thanks!!!
francis.
Posted on: 06 June 2003 by ChrisBathory
Hi Francis,
My sistem is 62 - Hicap - 110 (all dating back to mid 1980's), with Proac R1SC.
It works absolutely beautifully, to the extent that I really think any of the Naim amps will do a great job with your Proacs...
Happy listening!
Chris
Posted on: 06 June 2003 by David Stewart
Francis,
Welcome to the forum. You may get a better response to your enquiry if you give a bit more information on the rest of your system, your budget and whether or not you would consider second-hand kit.
Posted on: 06 June 2003 by slippery
sorry!!
My actuall gear is a Linn genky cd, Adcom gfa 555 II power amp, Trilogy 901 pre-amp and Proac
R 1 Sc speakers. here in spain Naim is very, very expensive (CD 5 cost over 1800 pounds, 2.600 euros) so i am strongly considering to travel to United Kingdom and buy there (is cheaper). The budget is around 4.500 euros, and yes second hand is a good option.
Thank you.
