AVG-where is it??
Posted by: max in hampshire on 08 December 2003
Ok I give up. Will one of you guys that suggested I use AVG as a result of my Norton AV post please tell me where I find it at download.com.
I have looked repeatedly under all the likely headings, and put it in the search box at download.com all to no avail. Where is it?
Come to that I can't see Adware or Search & Destroy either. Am I looking in the wrong place?
Thanks for any help.
Max
Posted on: 08 December 2003 by matthewr
http://www.google.com/search?&q=avg
Posted on: 08 December 2003 by Roy T
Max, download.com is also a place to look for lavasoft ad-ware and spybot D&D, if I've done this correctly you should see what you need at downloadcom.
Roy
Posted on: 08 December 2003 by Bob McC
Get it here
http://www.grisoft.com/us/us_dwnl_free.php
Bob
Posted on: 08 December 2003 by dave simpson
For addtional free security tools, go here:
Wilder's dot org
regards,
dave
