Uniti - Windows 7 Ultimate 64bit + Windows 7 UPNP
Posted by: Simon Taylor on 27 September 2010
I am running a Uniti - Windows 7 Ultimate 64bit + Windows 7 UPNP Server.
I initially had a few issues with it and after reading this thread did some investigations of my own:-
This post
There are two ways I use this integration:-
1) From Windows media Player 12 - Play To
2) Browsing shared media on Windows 7 PC from the Uniti
Looking at this using Wireshark i discovered:-
In both situations it works fine if the Uniti has just been turned on and switched to UPNP input - in which case I can see lots of
SSDP M-SEARCH * HTTP/1.1
SSDP NOTIFY * HTTP/1.1
traffic from the Uniti out to the network - once that has settled down the Uniti either
a) starts playing the music in case 1) OR
b) presents me with a server that i can browse from the Uniti interface
However, If the Uniti is on and the PC gets booted then switching the Uniti from UPNP to another input and back to UPNP doesnt appear to trigger the same SSDP traffic and I get issues with the Uniti not accepting traffic from the PC or being able to browse it. A reboot of the Uniti solves this everytime.
It appears something else occurs on reboot that doesnt occur on input switch.
I am running Uniti @:-
Firmware Date: 2009-12-14
Firmware Version: 2.1.1.10198
Is there a firmware update that resolves this behaviour??
Simon
This post
Simon
