I need a Naim interconnect, what should I do?
Posted by: silklee on 23 August 2002
Guys, need your opinion on this.
I am using a cd5 now but I don’t have the naim interconnect (is it called the NAIC) for the cdp to pre. I am going to get a used 92R/90 to try. The problem now is I need that naim interconnect, if not I wont be able to connect the cd5 to the 92.
I tried calling my dealer. He doesn’t have stock of the NAIC and even if he has, I think it is too expensive.
And I need to get a NAIC pretty soon as it wont be nice for me to hold on to the 92/90 for too long.
The other option I have is to get my blue heavens, which I am using for the IC from the cd5 to my present pre, reterminated to DIN on the other end as well. This would cost about half of what the NAIC would cost me.
Have anyone tried comparing the blue heavens to the naim IC? Is it worth the trouble or should I wait and get the NAIC from my dealer?
Also, could someone help me find out the cost of the NAIC in UK so that I can really judge for myself whether the NAIC is over priced over here.
And will naim UK entertain me if I emailed them and get them to ship me the IC? Does anyone know how much it will cost if that is the case?
Thanks in advance.
Thanks in advance.
