Fuses warning
Posted by: Sean P on 05 March 2001
Having just blowen the surge fuse on my supercap I thought I would post this warning
1 Dont pull the IEC connector and then try to reconnect with the supercap switched on Stupid I know
2 When removing the fuse to replace it be careful that little blighter can disintergrate and leave you fingertips full of glass! That why it bloody dificult typing this message.
3 What type / make of fuses should I use; are RS ok I note that my secondhand 135s have RS fuses fitted everything else has / had the original naim fuses.
watch those fingers
Sean
