I Want My CD5 to Play CDR-Ws!
Posted by: Mike in PA, USA on 02 March 2004
Anyone know if an update is in the works, or even possible, for this?
-M
Posted on: 02 March 2004 by gavagai
Yes,
Its called the cd5i. Razz
Posted on: 02 March 2004 by Wolf
I've heard that the r-w version of CDs is problematic and that plain R is best.
glenn
Life is analogue
Posted on: 03 March 2004 by kj burrell
I think you can get a software upgrade. I got an ex dem CD5 a couple of months back which does play CDR-Ws. I had read that the 5 didn't play these but the dealer told me it had been sent off for an upgrade a couple of months before.
Kevin
Posted on: 14 March 2004 by woody
Originally posted by gavagai:
Yes,
I don't think so!
Why not just use CD-Rs?
-- woody
Posted on: 14 March 2004 by David Dever
...when CD-R blanks are so inexpensive? The CD-RW blanks don't sound as good.
Posted on: 14 March 2004 by domfjbrown
...and the 5 WITH PIC upgrade will definitely NOT play CDRWs - just master on CDRW, then burn to CDR if you have to use an erasable disk during the mastering of your comps.
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
