Oxidised Fraim
Posted by: KC on 24 August 2002
Does anyone has any problems with the ball bearings that support the glass? Mine have all oxidised in places where the ball bearings come into contact with the glasses.
Posted on: 24 August 2002 by Jez Quigley
You should have bought mana/quadraspire/hutter/isoblue/base.
ps. Did Vuk ever suffer from rusty balls?
"All systems are perfectly designed to get the results they get."
The above was just a bit of 'fun' sorry if it added to your anxiety.
Due you live in a particularly humid place? Or is your partner an enthusiastic wet cloth waver like the present Mrs Quigley ?
I'm sure Naim will be interested in youe experience and should be able to advise you on a remedy (a light wipe with WD40 perhaps?)
Posted on: 24 August 2002 by rch
Concerning the price this experience of yours is more than disappointing. Possibly they'd change them, if your Fraim is under warranty?
Christian
I can't believe they weren't stainless steel in the first place like Vuk's
Posted on: 24 August 2002 by Paul Stephenson
Email naim and we will replace your set! There is a reason for everything we do!
[This message was edited by Paul Stephenson on SATURDAY 24 August 2002 at 21:26.]
Paul,
but what's the reason for not updating your homepage??
Christian
just too busy, it will happen soon.
Pauld, thought it might be a bit deep for you......
My 552/500 has oxidised so badly it now looks just like a 72 and pair of 135's, can you change it for a new one?
