Naim App
Posted by: docmark on 17 May 2010
Does anybody know if the Apple Naim App is able to browse & select network shares?
Posted on: 17 May 2010 by gone
The app simply allows you to browse what the HDX can see. Any shares or music stores that are active on the HDX are visible on the app as one big music library - there's no distinction between different locations
Posted on: 17 May 2010 by nicopra
I'll take advantage of this thread to ask:
Does someone know if Naim is planning to release an iPad version of the app?
Posted on: 17 May 2010 by Robbert
Another question about the app. Is this also for use with the uniti and unitiqute?
Posted on: 18 May 2010 by SC
Naim have said they will support the iPad - but it's anyones guess as to when that will actually be....
As for the current App, it is for HDX/NS only - there is a separate Uniti App on the way, although again, that statement was some time ago.....
p.s. I have a hunch Naim may now be occupied writing new code for the unreleased Apps, since Apple amended their SDK and blocked authoring with Flash...
Posted on: 18 May 2010 by gone
Only the HDX GUI uses Flash, for browser connection - the iPhone/iPod is different, so I doubt it was authored with Flash. It is so similar to the iPod interface that I suspect there's a lot of shared code
The HDX app will work with UnitiServe also I believe (when it's available Roll Eyes )
There we are, one post with 'doubt', 'suspect' and 'believe' in it. It must be true Winker
Posted on: 18 May 2010 by pcstockton
They should work on the iPad now right? It of course isnt yet written to fill the entire screen but that is the case with 99% of the current apps. it is either run in iPhone size or magnify to full size and lose the resolution.
-patrick
Posted on: 22 May 2010 by connon price
Isn't the new iPhone supposed to have the same resolution as the iPad so eventually all apps will need to be scaled up to the higher resolution, true?
But of course they won't be the same apps as the difference in size of the two screens really requires very different screen layouts.
