Nait 5 and source for 800£
Posted by: Nuno Baptista on 12 July 2002
Hello:
A few days I put a argue about Rega Planet and some guys make some notes about a PLANET 2000 source in this forun.For 5oo £ is the best source,no doubt!But I need a more powerfull source for my Nait 5 amplifier ,Ì want to spend 750 or 800 £ in a source!Any idea like a Marantz CD MKII 17 or a Linn source?I think some guys have the same problem,so you should listen a source,I´d like to have your comments!
Posted on: 12 July 2002 by Simon Matthews
I think that the extra spent on a CD5 will be worth it in the long run. You will be happy and will have a good soln which will last years and provide loads of entertainment.
If you save a little with a compromised player you will NOT be totally happy. You will also have a mass produced machine which will be worth very little in two years time. If you can afford to get what you really want now you will not regret it in the longer run.
Posted on: 12 July 2002 by Nuno Baptista
Hello:
It´s not easy to get a second hand cd 3.5 and it costs 660 £.But it´s a good idea... wink
