Stageline - Which One???
Posted by: Greg Beatty on 22 January 2003
OK -
I'm getting along well with the Nait 5 :-) and have hopefully found speakers that will do the business and that the Nait can drive (Meadowlark Audio Swift or Kestrel 2).
Now, to get my LP12 playing I need a Stageline. My dealer has, of course, recommended other phono stages but does not diss the Stageline in the least - he thinks its likely that it will be preferred in a Naim system and among phono stages at or under $500 USD.
But which Stageline to get?
I'm currently running an LP12 Basic/Cirkus/Akito/K18II so moving magnet boards are needed.
I'm also looking towards the future as the K18II will not last forever and the Stageline is not 'switchable' between MM and MC.
A search of the forum turned up quite a few nice cartridges for under $500 USD - Dynavectors and the AT OC-9 among others.
The Dyns are available in high-output versions, so again, I'm thinking I'm OK with the MM Stageline. I can use my K18II now and upgrade later do a MC high output (from Dynavector or someone else) and all will be well.
Is this a sound plan?
Also, if this is a reasonable way to go, do I order the Stageline with E or N boards?
What boards are you using?
- GregB
Insert Witty Signature Line Here
- GregB
