Identifying AV" output cable
Posted by: rhawkins on 31 May 2006
Can anyone help me identify the cable I need to output from Analogue 3 to my pre? I used to do this before, and I thought the cable was a thin grey type with a purple band at the input end, but I can’t find that cable anywhere – maybe I imagined it? The two other thin IC’s I’ve tried don’t work!
Any help much appreciated
Richard
Posted on: 01 June 2006 by AV@naim
You need a 5:5 "reverse" interconnect.
(yellow banded)
This is used from AN3 (AV2) to your pre-amp unity gain input.
Posted on: 02 June 2006 by rhawkins
Thanks for that
I tried the yellow band cable before without luck, but i think it must have been a software issue, as switching off the AV2 for a while and trying again has solved the problem.
thanks again
Richard
