The 300 has landed...out go the 270 (2x135s)
Posted by: Ron Toolsie on 21 December 2002
Patience is its own reward they say. But patience is only a virtue; it cannot propel a pulse of well tempered electrons through the voice coils of my DBLs. For that I required not merely patience, but its fruits.
I had ordered the NAP 300 at least six weeks ago and it has been at the dealers (Sound Image, Atlanta) for several weeks as Richard nobly volunteered the loan of his NBLs full-range load to allow the 300 to 'season'- a term I find rather more appealing than 'break-in' or 'burn-in'. In its fully unseasoned cold-out-of-the-box state he professed it to be initially 'nice' but hardly earth shaking-in ways both figurative and literal. But as has already been pointed out, its big brothers seasoning period is more akin to that of a new preamp (i.e. weeks) rather than that of a power amp.
And indeed as the days slipped into weeks it was apparently becoming obvious that if I left it chez Richard much longer, I would have to eventually prise it out of his cold and lifeless fingers. So rather than having to perpetrate this act of dealercide we agreed that today would be the day of delivery.
Eleven a.m. eastern standard time eventually arrived and with it both Richard and Lawson. The two shipping boxes were brought upstairs and the ritual of unboxing commenced. The two chasses (the power amp itself and its seperate remote power supply) are identically sized to the 135s they were destined to replace. The similarities did not end there- they too rang in a clear bell-like tone when the upper chasses were (gently) percussed with a curious fingertip. Hopefully there were greater electrical sonic differences than there were between their mechanical sonics.
Dont ask me why, but I expected a stereo signal input cable, a la 250/200/150 etc- but there were two nice, shiny and seasoned mono cables, just like the 135 cables I already had inserted into the Snaxo. So initially I used the input cables that were already there. Two sets of speaker outputs at the back- no suprise. The speaker cables were than plugged in, not without some anticipatory haste, but remembering to invert one of them to maintain the +--+ configuration common to all of the NAP stereo amps.
One or two tracks were played to make sure that their delivery had not resulted in stillbirth-which it hadn't. The very early impressions were quite favourable, but I did not have time to analyze just where these obvious benefits were occuring for we had another appointment to meet- lunch and a trial of a pair of different subwoofers in an active Tukan system that was at least an hour away from here. So with some reluctance I exited from the music room while rationalizing that the ensuing period of absence would only allow the 300 to warm up and sing truer upon my return. The subwoofer tests were equally as interesting and very instructive. I will have to distill our experinces there into another thread for this one is already being spun into a yardage of yarn.
Anyway, my period of absence (?seperation) was about seven hours. A good chance to let the NAP300 start its process of warmup. Bear in mind that even a vintage 52 once powered down can take days to 2 weeks to come back to full tune. I expect the NAP300 to require a similar period.
So, it was time for me to relax on the sofa and go though the agonizing decision of just which one of the many, many CDs would lead off. After scanning several alphabetized rows of disks my eye settled on McLachlan, Sarah. It would just HAVE to be her Fumbling towards Ecstacy album, specifically the track 'Ice'.
For those of you who have experienced the 552, or at least digested one of the reports of it on this very forum-including one by yours truly- those adjectives are certainlly not misplaced when describing how the 300 outperforms the 135s even when powering only a pair of tweeters.
The first thing that struck me was the very wide range of frequencies that appeared to have been affected. If for instance you turn off the amps powering the bass drivers and the mid drivers, you hear only a tsssk.... tssssk....fssssst disembodied type of sound that in contrast to the tones outputed by the midrange drivers are barely recognizeable. Indeed it is possible for some folk to blow a tweeter (or two) and not pick up on it for some time.
How then can improvements in this bandwidth manifest themselves far, FAR lower down the audio spectrum. Sure, things sounded much cleaner, sweeter, articulate and unforced at the upper registers- no less and probably more than you would expect. BUT the midrange took on a very natural, uncolored and beautiful aura to it that greatly reminded me of the qualities passed on the the mightly 552. Even more counterintuitive was the bass now appeared even tighter and more tunefull! How can this be- the DBLs 15 inch bass driver does not even stir until about 300 Hz or so....WAY lower than the highpass point the Snaxo sends the tweeter. I had to play 4-5 disks to convince myself that I was hearing large improvement apperently in the entire audio bandwidth.
If I had to attempt to explain this, I would note that even intruments with very low fundamental tones have harmonics far higher-in multiples of octaves even. So by improving the clarity and leading edge of the HF you can conjure up a clearer midrange and a snappier bass. Well, thats MY explanation anyway.
Soundstaging was good.. very good by DBLs standards, yet I felt that something intangible was awry. I got out a test disk and played the channel identifying tracks. Sure enough when the voice was supposed to be coming out of the left speaker only there was some of the 'tssssssssk, tssssssssk' sounds coming from the right tweeter while the left tweet was silent. A quick flip through the manual revealed the cause. I had the 135s stacked up (on a rack) that when you faced them the right hand column fed all three drivers of the right DBL and the left column nourishing the left DBL. So when I connected the 300 up, I put the speaker cable to the right tweeter on the right side of the amp; and the left to the left side. And of course Naim stereo amps have the left speaker on the RIGHT side of the rear panel (when facing the amps from in front) with the left channel being on the right side. This then was responsible for the tweeter channel inversion. Well at least I didn't connect the tweeters out of phase.
Once absolute laterality had been restored the soundstage became rather more defined and-dare I say- solid; in a way that one does not expect from the DBLs.
In this very preliminary digest, it is quite obvious that the NAP300 is in an entirely different league than the once-revered NAP135. The king is dead...long live the king!
More to follow.
Ron
Dum spiro audio
Dum audio vivo
Posted on: 22 December 2002 by Paul B
Ron:
Very interesting Ron. Thanks for posting your first impressions. Make sure you give us an update later.
Out of curiosity, does the 300PS have two Burndy interconnects similar to the 500PS or does it use a single Burndy cable (or possibly only a standard SNAIC)?
Paul
Posted on: 22 December 2002 by ken c
ron, excellent write-up!! normally i struggle to read long postings, but i read yours to the end with ease.
do you reckon you are (at this early stage) getting more bang with 300's than you would have with the 552 --- if you see what i mean...
please update us when the 300's ae fully, ehhh, "seasoned"...
enjoy
ken
Posted on: 22 December 2002 by Ron Toolsie
The single 300 offers a sneak preview, if you will, of what I remember the 552 offers. In a single amp passive system (or maybe using 3x300) it may be a toss up between going for the 300 or the 552. Not here though...the 552 dramatically improved every aspect-tone, emotion, timing, extension, purity, separation, inner detail to an alarming degree. The introduction of a single 300 by contrast allows some of these improvements to shine through, but not to an equal degree. With a 552 upstream the 6x135s can sing like I have never heard before. I think that the weaknesses of the 52 and the 135s probably are multiplicative. Improve on either and the faults of the other can appear far less pervasive. So the 552/135 can do almost all the right stuff, as can the 52/500.
There is little doubt that the 1x300/4x135 combination is allowing me to access the inner beauty of many recordings that were too easily glossed over in the past. If you promise not to tell anyone I may mention that I listened to two Abba CDs in their entirety this morning and was in awe in the creativity of the production and in the way the vocals so beautifully intertwined-even with a varyingly murky production battling against it.
Ron
Dum spiro audio
Dum audio vivo
[This message was edited by Ron Toolsie on MONDAY 23 December 2002 at 04:25.]
Posted on: 23 December 2002 by Alex S.
I must get a 552/300 immediately to see how they improve my Abba CDs.
Alex
Posted on: 23 December 2002 by Greg Beatty
...are out of my price range, I'm curious how the single 300 alone would do with your DBLs.
DBLs have a reputation for not being the most difficult load, and when the 500 came out the buzz was that a 500 passive beat a six pack.
Any chance you might try this?
- GregB
Insert Witty Signature Line Here
Posted on: 23 December 2002 by Ron Toolsie
I would love to try this out, for at least the sake of experimentation. Although for my long term purposes this is a moot point as eventually I intend to have the full brace of 3x300 into active DBLs.
Also it is possible that while a 300/passive may beat 6x135 active, the 1x300/4x135 active may trash the 1x300/passive. All I can say is that the current blend of 300 and 135s running active is producing by far the best sound I have had in this room with the DBLs with gear that I own. The 552 that was in residence only for a brief period of time allowed an unargueably higher level of performance by whatever standard you choose to judge it.
Late yesterday night I had another listening session. Now the 300 had warmed up for 36 hours the whole system was sounding much better than on the previous night. The very top end took on a glorious liquidity and was obviously far more detailed and inflective than it was on the evening before. The warm up period truly does appear to be far longer than the 135s which takes no longer than an hour or two after switch on.
I suspect the best is yet to come.
Ron
Dum spiro audio
Dum audio vivo
[This message was edited by Ron Toolsie on MONDAY 23 December 2002 at 20:14.]
Posted on: 23 December 2002 by ken c
ron, many thanks. i suspect sooner or later, you will have a 552 for the "full effect"
enjoy
ken
Posted on: 23 December 2002 by Paul B
The very top end took on a glorious liquidity eek
Oh no! Ron is a developing a case of round earthiness. Next thing you know he'll be raving about the dark chocolat bass (with a hazlenut interior) while listening to the spaces between the musicians in the huge soundstage thrown beyond the perimeters of his room.
Keep it to the PRAT, man! wink
PS Only joking. Keep the reports coming, Ron.
Paul
Posted on: 24 December 2002 by Ron Toolsie
You know, round earth attributes can be very involving. But it takes a very carefully selected and set up system to allow both round and flat earth parameters to come through without one acting against the other.
As has been alluded to since the inception of the CDS2, the signature sound of the newer products is diverging away from the exaggerated leading edge brashiness, the rolled off (but still tuneful) LF end and near total lack of soundstaging.
Although it has been argued that soundstaging never exists in vivo, neither do we listen with our ears scattered around like the microphones. And if we DID listen to music the way we naturally hear, we would revert back to recording with a pair of microphones stuck down the earholes of a dummy head (or the more conventional so called crossed pair), and play back through headphones- which DID give huuuuuuuge soundstaging.
I don't know about you.. but I am avidly welcoming the ability to seamlessly bridge the round and the flat. Maybe this should be called the 'oblate spheroid earth sound'.
Ron
Dum spiro audio
Dum audio vivo
Posted on: 24 December 2002 by Paul B
It would be a very good thing if this can be done successfully. I hope, honestly, that Naim have succeeded.
In the meantime, we need another acronym to indicate the "new" parameters of round + flat earth. Perhaps 'oblate spheroid earth sound' (OSES) could be 'mucho oblate spheroid earth sound' - MOSES! A new direction and leader in sound reproduction wink
PS Sorry for the the drivel above.
Paul
Posted on: 24 December 2002 by Roy T
The Mega Universal Sound Intergalactic Continuum.
Posted on: 24 December 2002 by Matt Gear
Ron
Interesting write up. All much out of my price range at the moment but was wondering about your decision to aim for 3 x 300's active? What was the rationalle behind aiming for this, as opposed to passive 500, which would actually be cheaper. Have you done the demo? Would be interested to hear.
(Why on earth am i online on Christmas Eve? Back to the mulled wine. Happy Christmasn everyone!)
cheers
matt
Posted on: 25 December 2002 by graphoman
Alex S. said:
“I must get a 552/300 immediately to see how they improve my Abba CDs.”
There is written in the Book: having invented the Phonograph, the very first melody Edison recorded was “Mary had a little lamb, little lamb...”, just for proving the quality of his HI-Fi. If it was good for the Master, must be enough for sure when proving our humble 552/300.
graphoman
Posted on: 25 December 2002 by Ron The Mon
Graphoman,
Getting way off topic here but I once actually got a chance to hear Edison's "Mary Had A Little Lamb". Just to keep the cylinder active (mostly the spring from snapping under stress) they play "Mary" and several other recordings yearly on the anniversary. I was there on the hundredth anniversary. A day I'll never forget.
Can't believe anyone will say the same about listening to ABBA 70 years from now!
Ron The Mon,
Needle-Freak
Posted on: 26 December 2002 by graphoman
well, it must be nice to be present on that performance.
On the other side, singing “Mary” or anything must not be that easy job for Edison, since (if I can trust my lectures) he was an absolutely unmusical man. Among the 10 main aims of his patent there were many interesting ideas, e.g. the phonograph could replace stenography etc. but nowhere a single word about music.
graphoman
