Anyone using PMC LB1 Lodspeakers
Posted by: quickie on 28 November 2002
Can they be placed close to the back wall?,say about 8" behind them.
Paul.
Posted on: 28 November 2002 by Steve Toy
The only way to find out is to try it out.
My own speakers are supposed to work 20cm from a back wall. In my room, they are at 60cm. I tend to start with the manufacturers' recommendations and end up with something different. big grin
Every room is different.
Suck it and see old chap, it's the only way to go. A decent dealer will let you do a home dem.
Steve.
It's just a pleasure to hear music as it was intended to be heard.
Posted on: 29 November 2002 by steved
I have PMC FB1's, which I think are the floorstand version of the LB1. Mine are about 8" from the rear wall, and they sound great.
STEVE D
Posted on: 30 November 2002 by quickie
Thanks Steve.
Paul.
