Problems with cd 5
Posted by: Nuno Baptista on 06 July 2003
I´ve got my CD 5 connected to Flatcap 2.When I disconnect today from Flatcap 2 it doesn´t work,no sound What happens?Is it the link plug it needs?
MY system : Naim Nait 5 amplifier,Naim cd 5 ,Epos M 15 speakers,Naca5,FC2
Posted on: 06 July 2003 by garyi
Yes, it needs the link plug supplied with the CD5. Its the same with pre amps as well.
Posted on: 06 July 2003 by Nuno Baptista
It´s done I put the link pluk in place and is playing
Thank you
Posted on: 06 July 2003 by Greg Beatty
But why...
...would you play it without hooking up the FC2?
- GregB
Insert Witty Signature Line Here
Posted on: 06 July 2003 by Steve Toy
But why...
Nuno,
Do you now have output A or output B connected to your CD5?
You need to remove the link plug again when you reconnect the Flatcap 2.
Steve.
