20" Flat screen T.V on Fraim
Posted by: timoth on 14 July 2009
Hello:
Short of space and wondering if ok to put my 21 inch t.v on my top fraim? Weight very little, maybe 10 pounds.
Posted on: 14 July 2009 by timoth
Should have said small flatscreen.
Posted on: 15 July 2009 by Engelbert
Not sure whether it's safe to do so or not - but if you try I'll bet your picture and sound quality will improve significantly. FRAIM does amazing things for electronics!
Engelbert
Posted on: 15 July 2009 by SC
Of course it's 'safe'...Just look at the structure...
Try lifting some of the Naim black boxes...
Steve
Posted on: 15 July 2009 by garyi
Its a safe as anything sat on 3 ball bearings can be. As long as no kids a present you'll probably be fine.
