Rega Three Compatibles
Posted by: garyi on 30 December 2001
I spotted a R3 deck online going cheap, I would expect its sold by now but was wondering...
Do the R2 and R3 only work with RB250 and RB300 arms or is it possible to use other arms, and would this be a pain in the arse.
Thankyou muchly.
Posted on: 30 December 2001 by Mark Dunn
Hi garyi:
It's a PITA because the Regas are normally drilled for Rega arms (naturally), other arm manufacturers rarely use the same diameter mounting holes and then you have to consider if the arm you want to use has the same effective length as the Regas, - otherwise you may have cartridge alignment problems. Personally, I wouldn't change arms.
Best Regards,
Mark Dunnr
Posted on: 30 December 2001 by garyi
Thanks Mark, only this one for sale is sans arm, so I was just wondering, I'll probably wack the 250 on for now, supposing its still for sale that is.
Posted on: 30 December 2001 by Paul Ranson
IIRC the Rega arms are slightly longer than Linn standard, which makes adapting a deck drilled for Rega tricky.
It's easy on an LP12, armboards are relatively cheap. Somewhere I have one of the first 100 RB300s on a Linn board.
Paul
Posted on: 31 December 2001 by garyi
Why does everyone have better deck arms knocking around than me?
