AVG 8.5 auto update.
Posted by: Adam Meredith on 28 April 2009
You may want to watch out for this.
I believe that some time ago AVG offered me this update and made a minor install - followed by a message that it would perform the full update in around 20 days - possibly to stagger demand on their servers.
AVG also made it enormously easy to download the pay for version - by mistake.
This unexpected message worried me but I left things as they were for a few days. After an inelegant shutdown I asked the machine to schedule a disk check on next re-boot. Since then every boot flashed up:
checking file system on C:
The type of the file system is NTFS.
Cannot open volume for direct access.
Windows has finished checking the disc.
access to C: appeared to be dog slow and the machine generally felt sluggish. I downloaded 8.5 direct from FileHippo but the problem persisted.
I had thought that this was the beginning of a fatal problem with my HD and looked to various (extreme) solutions - pretty much deciding to reinstall Windows - probably involving a reformat and loss of settings, etc.
Instead I uninstalled AVG and, since then, all seems to work as per usual. I haven't re-installed 8.5 for the moment.
Has anyone else experienced this?
Posted on: 28 April 2009 by Officer DBL
Hi Adam,
I had a similar problem with an install of this "upgrade" on one of our computers. It took a couple of uninstalls and reinstalls to get it working. I think the problem was with the data being corrupted during download and only when an "intact" download was achieved did the program decide work properly.
You are not alone.
Brad
Posted on: 28 April 2009 by Tony Lockhart
I gave up with AVG after 9 years last year. I bit the bullet and paid a few quid for Kaspersky. What a pleasure. Runs in the background, doesn't slow my machine down, does what it should.
Tony
Posted on: 28 April 2009 by Diccus62
I use version 8.0.238. It occasionally shows up on my Microsoft Security Centre as not being switched on (when it appears to be). Yes it slows down my PC when its running. Never had a virus with it. Its free.
diccus
Posted on: 28 April 2009 by Adam Meredith
Just clean installed 8.5 No problems as yet - none expected.
I think it was the delayed upgrade thing.
Posted on: 28 April 2009 by Bob McC
Munch
Why not tell all of us where we can get a clean download of a free application?
Posted on: 01 May 2009 by Blueknowz
I use AVG(Version 8.5.287 free version ) on my laptop with no problems downloaded it from comupteractive.co.uk ,On my main PC we i=use a paid for Anti Virus Steganos which basically Kaspersky but cheaper !
