NAIT now in main system - but rough with vinyl - any ideas?
Posted by: domfjbrown on 18 August 2003
I finally got round to swapping my Rega Mira 2k and NAIT3 around this weekend, as the NAIT for bedroom hifi use was no good, due to the imbalances in the volume control at low levels - ie, any time with a bedroom system
Anyway, the NAIT was powered down for about 20 minutes whilst I swapped the amps and cables (both systems use NACA5 - black in tbe bedroom, white in the lounge - both 5metre runs).
I'm using a Rega Planet (original) and a Rega Planar 3/RB300/Ortofon 540, and am using Rega Ela (original) speakers. The system sounds damn fine with CD (and even DAB believe it or not) now the NAIT's in there, but the turntable sounds pretty nasty with marginal/worn records. I had the 540 fitted in April, and I've never been 100% happy with the alignment, but being partially sighted I've not played around with it. Now, with Kate Bush's "Kick inside" (don't laugh!) her vocals were clearly mistracking on "The man with the child in his eyes" - only on the left channel. I cleaned the stylus and the effect was reduced, but still there. This is a 2nd hand copy that sounded fine on the Mira, but the NAIT is much clearer and is thus reproducing faults I'd not heard before.
So - is the front end not good enough (I heard this same rig, using Dynaudio Audience 42s, back in 1998, with the same Kate Bush LP, in Audio-t, and this effect wasn't audible there. And the record's been cleaned since then...
I'm seriously wandering whether to try disabling the downforce dial, and setting the downforce etc by the counterweight alone, a'la the RB250, using my Shure stylus balance - is this likely to help at all?
I'm sure it's only the left channel that's sounding rough - and the effect isn't there with new and better nick vinyl, like White Stripes' Elephant, or XPress-2's Muzikizum...
Ideas please
Thanks!
When the music's over turn out the lights
Posted on: 18 August 2003 by Rico
Dom
you're now hearing what the Planar is capable of. Give it a thorough setup (get it to a Rega dealer for a warranty service) such that you know its totally kosher... if it still sounds awful and all other aspects of the system are working well, you might reconsider your position vis-a-vis the venerable LP12.
Rico - SM/Mullet Audio
Posted on: 18 August 2003 by domfjbrown
Hmm - well, is there a way I can try cartridge alignment myself without using the Rega special torgue tool (with the arm OFF the deck obviously), as the only store in Exeter (Audio eXcellence) that deals Rega is the one who put the 540 on (I don't trust them any further than I can throw them when it comes to my deck - I mean, they put the thing in the box upside down when they last looked at it.
Oh for Audio-T Reading, they knew their stuff far more...
Anyway, I'll have a fiddle and see what's what - my guess is anti-skate needs a bit of a tweak for a start.
Rest assured though that I will NOT be buying an LP12 - using them for me is a nightmare (sound aside) due to that bouncy suspension, although at least in my current place, footfall isn't such a problem. If I upgrade - it'll be to a P9 or something like a Garrard 401 (so I can reap the arm from the Rega).
Posted on: 18 August 2003 by David Stewart
Why bother with vinyl you say is worn/marginal anyway. There's really nothing you can do to improve it once it's reached this state and it'll likely damage your stylus anyway. I'd suggest you give up the unequal struggle and let it R.I.P.
Ah, but is it actually worn, or just my cart out of alignment, as it sounds perfect on my mate's Michell Orbe/SME-V/vdh Frog - which, admittedly, is waaaaay more expensive, but, will reveal groove wear on his records...
I'm wandering if it is just a setup issue?
Mmmm, could be it isn't worn vinyl then but just mis-tracking on the more dynamic bits, his setup being better isn't having the same problem. Worth spending out on a dealer-setup possibly and get them to check the cart/stylus for wear.
Posted on: 18 August 2003 by Brucie
domfjbrown,
Can't add to whats' already been said except there is no call for reservations about your music choice IMHO. "The Kick Inside" is a damn fine album!
b
Posted on: 18 August 2003 by Greg Beatty
If the harshness is just from one channel, it could be an anti-skating issue. I don't recall if left channel noise is due to too much or too little anti-skating.
Try adjusting the anti-skate while playing the record. Set it to taste. A slightly heavier tracking weight may also help.
- GregB
Insert Witty Signature Line Here
Except some people say it's not the best recording ever - sounds OK to me (on CD at least at the mo!). The cartridge is only 4 months old and I've probably got less than 50 hours on it, so I think that's safe. I'll have a play with the anti-skate etc when I have some time later in the week.
Oh - the Planar 3 is on 3 RDC cones - I'm wandering if that's not helping, as they helped the sound on the Mira, but there's so much more now anyway, I'm tempted to remove them for a bit to see how it sounds...
Posted on: 18 August 2003 by garyi
Dom my experience of the rega two was similar to most decks I would imagine. You need to insure its dead level, otherwise the arm and consequently the needle will be forced into one direction or another.
This will have an effect.
As for setting the weight. well on the ticktock you have the dial on the side, I tend to judge it roughly by this and also use a cheap 'proper' down force adjuster, about 7 quid from hificandy, to insure the weight is bang on. The dial does tend to be out.
I would also suggest you move to MC as soon as possible. I have used MC on my rega and it sounds supurb and a great way to move slowly up the ladder. I hear that rega them selves have an MC out, the exact? Might be worth saving the pennies for.
I would suggest that a bit of investment in the vinyl side will insure years of happy trawling through the record bins.
One other thing, swap the leads round, if it continues out the same side, it will be a problem with the nait, mabye the boards have moved in transit, if it changes side then its the deck.
Posted on: 18 August 2003 by Martin Payne
Dom,
I recently compared 'K' & 'S' spec Stagelines on my cartridge, and the 'K' occaisionally sounded rough where the 'S' was better (but not perfect).
That doesn't help much, other than to say that the NAIT may not be the best match for your cart.
Just one other thought - what boards are in the NAIT? MM/MCs/MCk?
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 19 August 2003 by domfjbrown
Cheers guys
Right - for clarification... I made sure my rack (I'm not saying what it is - it's junk and I can't upgrade it (yet!) is level when I moved in, BUT, I haven't checked the deck itself since it went on the RDC thingies. This will be first priority (I have a spirit level handy.
My thoughts were also re anti-skate - it's defo mistracking, not the amp, as new and good nick vinyl doesn't screech - my guess is maybe the tracking force is a little too light, or the antiskate is definitely ripe for jiggling with.
Can you adjust antiskate safely while the record's playing then?
I have the Shure stylus force gauge so that's covered.
Garyi - I *know* about MCs. I had one on it until April, when I broke it - I still don't know how. It was a Dynavector 10xGold and was lavish - gutted beyond belief. One day there was a nice cantilever, next day there was nothing - and no sign of it either! I still have the body for it so am thinking I might get a 10x5 instead, but it's the whole "blind git being hamfisted with stylus brush/cueing/etc" thing that puts me off MC - the main reason I took so long to get one in the first place
I guess though, at least, if you break a boron cantilever (ie the 10xGold) it snaps - a bent aluminium cantilever will knacker your records...
Ho hum
Oh - and it's the MM boards - whichever they are - revision 5 - I had them fitted in May. I don't THINK they've been dislodged but you never know... I'll certainly try swapping the leads round if nothing else helps...
I'll try all this out tomorrow night. I've got a brand new bike's (Specialized Hardrock - so the second part of the name's appropriate for me!) rear brake to fettle tonight - so in a hands-on-tweaky mode this week!
Originally posted by domfjbrown:
Cheers guys
Right - for clarification... I made sure my rack (I'm not saying what it is - it's junk and I can't upgrade it (yet!) is level when I moved in, BUT, I haven't checked the deck itself since it went on the RDC thingies. This will be first priority (I have a spirit level handy - and will try the deck with and without RDC to see if they're really neccessary with the better amp).
Ho hum
Posted on: 21 August 2003 by domfjbrown
Mark - I managed to level the turntable glass mat (rather than just the top shelf!) last night, and re-set the stylus force using my guage - it's set to about 1.8 grammes down and 1.7 antiskate now - and although "The man with the child in his eyes" still has a couple of edgy bits, it'll now track right the way to the end of "The kick inside" without hashing/hardening - so perhaps a bit of tweaking with anti-skate, but nearly there
I'll try removing those RDC cones again to see what shakes loose - it's not like an expensive/time consuming tweak to reverse after all
Everything I threw at it from Grease (don't laugh!) to Pearl Jam sounded MUCH better after tweaking the stand - much happier bunny now and CD now sounds a bit flatter again.
There was only one slight mistrack on the last track on Tori Amos' Under the pink - and it's on pink vinyl and needs cleaning anyway, so I'm not so bothered now
