AV speakers to go with Credos
Posted by: Ravvie on 30 December 2003
I have been wrestling with the problem of integrating AV into a Naim set-up. Dealers seem reluctant to take this one on, other than to suggest either a separate AV system or the full Naim route.
My critical listening remains vinyl, though we actually spend more time on AV.
Naim centres are unsuitable, mainly because they are physically too deep (dangerous for my 3 year old whose head is at my listening height), would look silly under a wall mounted plasma, oh, and price.
I wonder if a 3rd Credo (s/hand) would be sensible? A dealer (ex-naim) thought I was mad on the grounds that the Yamaha amp wouldn't drive it and wouldn't tonally match anyway. And of course I would have an odd Credo left over.
Previously I owned Mk1 Rega ELAs. Would s/hand Kytes be suitable for rears?
Have currently got a loan of M&K K7 centre and K4 tripoles. These seem to tonally match reasonably well but they sometimes sound like separate speakers. At £875, I'm not convinced, though I'll experiment more with positioning.
Have tried and liked the REL Quake, also on loan, though had nothing to compare it against. Seems to integrate well on LFE, using depth setting but not slam. Should I be aiming for a better sub in my set-up?
I'd appreciate any thoughts you have on these or other options.
Ravvie.
System:
LP12, CD3.5 (fc to follow)
72/hc/90 (180 or 250 to follow)
Credos
Pioneer 636 DVD, Sky+, Panasonic plasma
Yamaha DSP E800
Kef 90 centre & Jamo prologic dipoles from previous system
Ravvie.
System:
Credos
Yamaha DSP E800
