72/140/old hi-cap V 202/200/old hi-cap
Posted by: stray cat strut on 26 February 2004
Just wanting your views,on the diffrence that i should look out for between these two pre/power amps.I am looking to change soon.
My front end at present,LINN SONDEK/VALHALLA/TRAMPOLINN/ITTOK LV 11/ASAKA.
CDX/XPS.
These are feed to REGA ELA's
MARK (first post)
CDX/XPS.
MARK (first post)
Posted on: 26 February 2004 by J.N.
Welcome aboard Mark
The two amplifiers combos sonically define the old and new Naim sound. Very much a matter of personal taste. Both have their merits. 202/200 for me, by a mile.
Try removing the trampolinn and running the LP12 with no baseboard at all. Just insert the original 4 rubber feet.
Posted on: 26 February 2004 by syd
The other big difference is the cost. 72/140/oldHi will be available for a lot less second hand than the relativily new 202/200 even with an old Hi CAP. I think you would be pleased with either although the first would leave you with a lot of cash for CDs and LPs.
Yours in Music
Syd
Yours in Music
Syd
Posted on: 28 February 2004 by MarkEJ
Total no-brainer, IMHO. 72/Hicap/140, then blow the change on servicing the LP12, Lingo or Geddon and Prefix + another old HiCap and some blck SNAICs. This will improve both sources massively, since the pre won't be powering phono boards. Strictly speaking, it is only once you have done this that you could make a valid comparison between the two preamps.
Fun!
Best;
Mark
Fun!
Best;
Mark
Posted on: 28 February 2004 by JeremyD
I don't know what to recommend without knowing what amplifier you have now. If it is a respectable one then perhaps a Lingo and an Ekos [or Armageddon and ARO, if preferred] before upgrading the amplifier.
Posted on: 28 February 2004 by Basil
A word of caution, whilst I whole-heartedly agree with running an LP12 without a base board, doing so with a Valhalla equipped deck needs thinking about as the Valhalla PS carries large DC voltages plus mains (240v AC) currant.
Posted on: 28 February 2004 by stray cat strut
Sorry boys,you must have picked me up wrong,at presant i have the 72/140,with an old style hi-cap.I was looking to replace this,with the 202/200,and retain the old hi-cap.
The 72/140 were both serviced less than 18 months ago.
Just would like to hear,from someone who has done this move.As i know there is a diffrence between new and the old style.
I also dont want to play about with the sondek,as i'm happy the way it is.
Mark.
Mark.
Posted on: 28 February 2004 by sean
"I don't want to play about with my sondek"
Yes Mark I know your happy playing around with something else.
Sean.
Sean.
I suggest you find a dealer and arrange to borrow a 202/200 for as long as possible. Don't bother swapping back and forth between amps either just stick with the 202/200 until they have to be returned.
Trust your own ears.
quote:In that case I expect you would find even a 202/Stageline alone would be a worthwhile upgrade. The 202/Stageline is faster, has a better sense of pitch, sounds less bandlimited, has more natural dynamics, has a more realistic stereo image, has less subjective distortion and has a blacker [i.e. quieter] background.
I've never heard a 200, so I cannot comment on it. Having heard a 150 two or three times, my impression is that even a 150 may be better than a 140 - it certainly does some things better, which leads me to guess that a 200 would be a lot better...
However, given that you have decided not to upgrade your turntable, keeping your 140 and getting an 82 is an alternative option that might be worth exploring.
Posted on: 29 February 2004 by MarkEJ
Are you quite sure about this?
Your sources, while excellent, are not as good as they could be. The fact that you are considering a new amp does indicate a degree of disatisfaction. If your new amp is better, it will highlight any shortcomings with greater clarity.
Best;
Mark
Posted on: 29 February 2004 by billyj
Well, well ,well.
Marky Boy...
and seaney boy...
I guess you already know the answer to this question mark.
So spend less time on this forum and
get your arse down to my place and finish my Sound room.before I get back. Ok?
Talk soon.
BillyJ
Marky Boy...
and seaney boy...
Talk soon.
BillyJ
Posted on: 29 February 2004 by stray cat strut
Well sorry BillyJ,you know the Stonehaven road has been hit badly with snow,if it clears we might have a trip down to see Robert.Fancy that Sean.
Every one thinks i should waste my money on the sondek,i dont spin it the same,these days.At 12 years old,i think a new amp,suits my needs best.
Mark.
Mark.
Posted on: 29 February 2004 by J.N.
Mark
Whilst it is admirable in some respects not to be a constant tweaker, you really should try the Linn without the Trampolinn base.
This was designed to help the LP12 perform better on poor supports. If your LP12 is on a decent support system, the Trampolinn will seriously degrade it's performance.
One of the joys of a good turntable is that its performance can be dramatically enhanced by messing with its physical placement and support, at little or no cost.
If you have no dedicated support system for it; one may be fabricated at minimal cost to decouple it from 'massy' furniture etc:
Oak cone feet or three speaker spikes in a bit of MDF can work wonders.
Russ Andrews can supply a set of speaker spikes and threaded inserts for about £5.00 for a set of four.
Good luck.
Posted on: 01 March 2004 by MarkEJ
I think that as a 12 year old, you're very lucky to have a choice of two such magnificent sources
Try this: Pull the phono boards out of your 72, and listen to a CD. This will give you a taste of what a StageLine or Prefix could do for your CD replay ONLY. Then consider that the LP12 can improve on this -- is that really a waste?
Best;
Mark
