What Next?
Posted by: Alex S. on 27 April 2001
Its taken 25 yrs but I now have:
Main system
CDX with a CDPS
LP12, Lingo, Dynavector DV20-X
82 with 2 old Hi-Caps
2 X old style 250s
All sitting on Base 01s
Niam cabling apart from - Chord interconnect to CDX & Cabletalk 4.1 speaker cable
B&W Nautilus 805s on granite stands
(Most of the above 2nd hand but serviced)
2nd system
32.5/110 with Toshiba DVD and AE1mark 1s + various AV rubbish
What Should I do Next?
Nothing? XPS? Supercap? Take one Hi-Cap out of system 1 and put in system 2? Retire whilst waiting for Naim DVD-A?
Advice & comments please
Posted on: 27 April 2001 by Mick P
Alex
To my mind its easy
1. Sell off 2 old Hicaps
2. Buy new supercap...very few s/hand ones around.
3. Flog 82
4. Buy 52
Thats not too bad a system.
Mick
Posted on: 27 April 2001 by NB
Alex,
The question is what do you want to do next?
You have a well balanced system that should sound great, but are you happy with it.
AndyR has given some very good advice, enjoy your system and buy more music.
NB
Posted on: 29 April 2001 by Alex S.
I love my system - but then I loved the old one too, and that little upgrade bug still bites every 10 years or so and then leaves me skint another decade.
The LP12 has the humble Ittok but I don't want to upgrade the turntable for now.
I listen to system 1 at work which is:
good because I can go loud
bad because its a large concrete box which I cant change much
The better my system gets the less a bad listening room seems to matter!
It all sits on old Sound Org tables/racks with a Base platform under each piece of kit
What are the views on CDPS vs XPS
Is a Supercap that much better than 2 Hi-caps for an 82?
Cant afford 52
Does anyone recommend alternative speaker cable - I'm not entirely convinced by NACA 5 or CT 4.1 - I don't want to spend £300 pm.
Thanks Alex
Posted on: 29 April 2001 by ken c
alex:
yes.
enjoy...
ken
Thanks Ken - I suspected as much
Everyone
Since my last visit I've read more topics and donned anorak substitute so here goes:
Please choose where to place my equipment.
Choices:
Single old Sound Org Table
5 Tier old Sound Org Rack
Floor
All sitting on Base
Until 10 minutes ago it went thus:
Top shelf of 5 tier, CDX; shelf 2, 82; 3, CDPS; 4, 250; 5,250; Floor (on Base01 on MDF shelf from hideous dismantled TV cabinet) 2 HCs
Single SO table: LP12
I've just swapped the CDX with the LP12 and I'm either going mad or it sounds a bit tighter; (don't dare listen to Sondek).
I'm taking the rest of the week off!
Thanks A.
Posted on: 30 April 2001 by Alex S.
Thanks James - I'm hearing all the things I don't want to hear - I think I'll pass on the 135 dem until I've got more money!
I thought I had written semi-gibberish. . .What I hoped to say was that the CDX sounded tighter on a single Sound Org table than it did on the top of a 5 tier unit.
The LP12 is recently serviced but is only up to Valhalla spec and probably needs a new motor. .
and I wish I still had my old Troika.
