MacBookPro - nDAC - chassis/floating
Posted by: gav111n on 07 October 2010
I have read several comments over the months about selecting the ground switch on the nDAC to ‘chassis’ or ‘floating’. I remember js suggesting a few times to play around with this to decide which sounds best. Until now I have not bothered and left it set to the default of chassis because:
(1) The naim manual says you may need to change it to floating if you are connecting to a HiFi system incorporating another earthed component. I use MacBookPro>HiFace>DC1>nDAC+PS and listen to music with the MBP on battery, so no earthed component right?
(2) The naim manual says you may need to change it if you hear humming through the speakers. I get no humming.
(3) What difference can a tiny little switch on the back of the nDAC really make?
The other night I had the urge to fiddle and flipped it over to floating. I should have followed js’s advice months ago! It has improved the sound quality and it isn’t subtle, an effect not unlike adding the PS to the nDAC – more ‘real’ sounding – more focussed – more engaging. I don’t understand why though. Am I going mad?
Gav.
Gav.
