Best software for DVD to iPad?
Posted by: winkyincanada on 04 July 2010
Anybody have a view on the best software for taking DVD movies and ripping them to a format for iPad?
Thanks in advance.
Winky
Posted on: 04 July 2010 by garyi
platform?
Posted on: 04 July 2010 by Absolute
I you're using a Mac then use Mac The Ripper for the Initial Rip and Handbrake to encode to a format for iPad.
Posted on: 04 July 2010 by winkyincanada
Garyi, on a Mac.
Thanks Absolute.
Ripped a "wrong region" DVD using mactheripper and now Handbrake is doing the conversion. All good so far. Thanks guys.
And success! Thanks again.
Mac the ripper is a bit old school, rippit will rip and compress in one application.
So to will mac DVDripper pro.
Both are more up to date and reguarly updated for new codes in DVDs.
Posted on: 05 July 2010 by Gavin B
And what about for Windows?
I'm sure my son would love to be able to rip DVDs for his iPod Touch.
Gavin
Posted on: 05 July 2010 by Eloise
garyi... I think Handbrake will compress better than most alternatives so would stick with the two stage process.
Gavin B... For Windows - DVD Decrypter and then Handbrake
If you have a lot of DVDs you want to encode to MP4 for your iPad / iPod then may be worth investing in an Elgato Turbo.264 HD.
Eloise
Posted on: 06 July 2010 by Steve Bull
My one attempt at this convinced me that the easiest way to rip a DVD you own is probably to download it from the internet. It's just so time consuming!
