Naim Dac Ipod Touch Issues
Posted by: jrh on 17 November 2010
I've got a Naim Dac and absolutely love it. But I have a problem. 3rd and 4th Generation Ipod Touches occasionally have a skipping, stuttering, or static sound for short durations during songs at random times. I had both Ipods replaced and this hasn't solved the problem. I must not be the only one with this issue. Any suggestions?
Posted on: 18 November 2010 by Harry
I don't know if this will cure it, but have you updated the nDAC firmware? Instructions and file download are posted in the Distributed Audio section.
Posted on: 18 November 2010 by sheffieldgraham
The problem is with the Apple OS 4.1 software. It has a bug which is affecting many docking systems.
My Apple Touch was affected after upgrading from 4.0 to 4.1.
See Steve Hopkins thread on this
https://forums.naimaudio.com/ev...2903417/m/9832927437
There is a 4.2 upgrade from Apple imminently.
We're all waiting to see if a fix has been made.
