adsl filters?
Posted by: jason.g on 22 September 2006
I,ve just had broadband fitted through talk talk carphone warehouse. (i know-don,t start). I have 2 adsl filters supplied. One is connected through the pc, the other to my telephone. Problem is, I have another telephone which needs a adsl filter also. Do I have to buy the talk talk filter for £9.99 or can I use BT one off ebay for 99p.
Posted on: 22 September 2006 by BigH47
Either. I have amix of E-Bay and OEM(BT) and all seems OK. You can get them in Currys/PC World/Comet etc as well.
H
Posted on: 22 September 2006 by Derek Wright
Go to ADSL Nation
and read up on the Filters part of their forum, then if you are happy with the concept of the Master socket and the wiring of the phones in your house is similar to how they describe it get an XTE-2005 master socket filter
