prefix compatability
Posted by: neil w on 31 August 2003
could someone tell me if a k type prefix will work with an ortofon rohmann output is 250uv at a 1000htz ( whatever that means )
cheers neil
cheers neil
Posted on: 01 September 2003 by Laurie Saunders
I used to have a Rohmann. It worked fine. I found that the volume had to be over 11 O`clock before the sound came to life, though that will depend on the sensitivity of the speakers you use
Laurie S
Laurie S
Posted on: 01 September 2003 by neil w
ross and laurie
any chance of some photos of how your prefixes are mounted and positioned under your orbes
cheers neil
cheers neil
Posted on: 01 September 2003 by Tim Jones
Ross -
How have you boxed the Prefix? Or is it just left au naturel?
Tim (trying to figure out how to Prefix a P9...)
Posted on: 01 September 2003 by Jens
Neil,
I'm running the MC Rohmann with K prefix in my LP12. It's a great combination, and I find no difference in terms of how far I have to turn up the vol compared to the S boards the prefix replaced. I'd have no hesitation about recommending the combination.
Cheers, Jens
Cheers, Jens
Posted on: 02 September 2003 by Laurie Saunders
My prefix is bolted to a small slab of 12mm mdf fitted with four inset compliant feet. Like Ross` it sits neatly on the shelf directly under the arm. I had to send the prefix to Naim for modification...the "armlead" is now about 7 inches long, and of course, I had an SME plug fitted. I have no hesitation about recommending the SME/Orbe/Prefix combination
Laurie S
Laurie S
Posted on: 02 September 2003 by Joe Petrik
Tim,
Vuk's got his Velcro'd to the bottom of his P9. The connections, I believe, are hardwired.
Joe
...trying to figure out how to Prefix a P9...
Joe
