Nait 5 as preamp
Posted by: guy batey on 14 February 2001
If the Nait 5 is converted into a pre-amp, is it identical sonically to a Nac 112? Alternately, could you add a Nap 150 to the Nait 5 and biamp?
Posted on: 14 February 2001 by John C
Guy, if I remember correctly the 112/150 do not share the same internals as the Nait5 (unlike the Nait3/Nac/nap90). Therefore the NAC 112 is likely to be somewhat better/different. Interesting that Naim recommend adding the Nap150 as the first upgrade to the NAIT5 though.
Johnn
' if you are refering to the recommended systems on our website, the upgrades for the NAIT system are not listed in order of priority. Perhaps they should be!'
Especially for sheeplike followers of the WORD like myself. Time alignment filters eh? I really should stick to the music forum.r smile
John
(can't wire a plug)
