Is it worth Prefixing an LP12?
Posted by: Top Cat on 24 February 2004
Hi folks.
I had been planning to complete my system with the addition of a Prefix K phono stage (to replace the K boards in the 52) but lately I have been wondering whether it's really worth it.
What benefits over K boards in a 52 will a Prefix actually bring? My LP12 is fantastic on good quality vinyl and if I have a criticism it is that on average and slightly scratchy vinyl I find the LP12 is easily outclassed by my cd player. The deck has recently been serviced and is otherwise fine, but I'd like to know whether spending another few hundred notes on a Prefix is worth it.
The Prefix will be powered by the 52 - I am almost certain I will do this rather than using the Hicap as the Hicap can then be sold which will more than fund the prefix.
Any thoughts - particularly from people with similar systems to mine - LP12/Geddon/Aro/Helikon, 52/SC/250.
Thanks,
John
Thanks,
John
Posted on: 24 February 2004 by Peter Stockwell
Originally posted by Top Cat:
...and if I have a criticism it is that on average and slightly scratchy vinyl I find the LP12 is easily outclassed by my cd player.
I'll bet that's due to all the work you've done to make sure that your system has a good electricity supply. I'm thinking, more and more, that a lot of what ills CD is due to poor electricity supply.
Peter
User34 at Laposte dot net
Posted on: 24 February 2004 by kan man
TC you need to clean your vinyl!
Fwiw I didn't really 'get' the Prefix in a dem when powered from the amp (I was a bit demmed out from choosing between Lingo and Geddon tho). I did get it once a hicap entered the equation. This is still less of a change than better power supply and imo, the prefix really comes alive with a s/c.
System as yours except sc-prefix, 17D2
Steve
Steve
Posted on: 24 February 2004 by Top Cat
Well, I have a VPI 16.5 but though it cleans stuff up it can't fix damage that's already been done - and I have a lot of older LPs that are a little scratchy, etc. VPI thoroughly recommended, though.
Hmmmm... in the short term the funds saved by not using the HC would probably also go partly into a 250->135 opportunistic upgrade (this is something I hadn't planned but what the heck)...
By powering from the 52 I can always add a SC should one turn up at a cheap price (and should pigs fly
John
Posted on: 24 February 2004 by ken c
Originally posted by marky L:
I don't understand why a Supercap should power a Prefix any better than a Hi-cap.
neither do i. but it does; and emphatically so.
in fact this input 1 on the supercap also weaved its magic on my nac112 during the time i was waiting for my 252. i was shocked.
i have said this before, but i believe that there is a gap in the naim p/s range. what is missing is whatever it is that the prefix uses within the supecap when powered by it. and i said i would buy such a p/s for my prefix; but fully understand that there may not be many people like me around to make it a viable business proposition. ah well...
i guess one can get a pre-loved supercap for reasonable money these day, so... just sold one of mine -- went superfast!!
enjoy
ken
Posted on: 24 February 2004 by David Stewart
quote:I just tried this test on my Nait (with LP12 and MM boards). For any given setting of the volume control, I was unable to detect any difference in the background noise level between phono and CD inputs.
if you set normal vinyl volume level and select phono input on the Pre (with no sources playing), you will hear a certain amount of background noise through the speakers. If you then select your CD source you will hear a much reduced level of background noise. Now imagine your phono stage about 80% quieter; that's what a Prefix does.
Actually there was barely any discernible noise at all on either input until the volume control was around 3pm, far higher than I'm ever likely to set it for 'normal' listening.
Surely the Prefix needs to offer more than this to make it worth the (considerable) extra money
Posted on: 24 February 2004 by MarkEJ
TC, I cannot speak from experience as I don't (currently) have a Prefix, but IMHO the thing is a thoughtfull and truly clever piece of design.
1. Reducing the length of the cable which conducts truly tiny voltages from a few feet to a few inches makes a lot of sense.
2. Elimenating the effect and potential inconsistencies of the critical dressing of the arm cable on the LP12 makes a lot of sense.
3. Powering a Prefix separately means less demand on the preamp power supply than phono boards, so other sources should also improve -- makes a lot of sense.
4. All this means that from the manufacturer's POV, the Prefix has big benefits, so you can charge quite a lot for it. Even better, internal plinth fitting means you save the cost of a case, not to mention transport costs, PLUS you have potential upgrade power supply sales at a later date, AND your dealers get to charge labour for installation.
The whole thing is magnificently brilliant. Damn, I want one now.
Best;
Mark
Originally posted by David Stewart:
Actually there was barely any discernible noise at all on either input until the volume control was around 3pm...
David, that's because you have MM boards. The gain in MC boards is many times more.
Best;
Mark
Ah right! - I hadn't thought of that, but even then the gain of MM boards must be many times more than line level inputs. Some of the other points you raised are interesting though, but I still question the VFM of a prefix upgrade. No doubt others will dissent though.
quote:OK Patrick, I feel suitably 'put-down'. Thank you for helping me to understand that for 'big-hitters' like yourself and TC the Prefix really is excellent VFM
So whilst I can understand that if you have a Nait2 and a MM cartridge your priorities will be elsewhere
quote:It's what life's all about - n'est pas?
David, I'm very happy to have been able to help.
Posted on: 25 February 2004 by David Stewart
quote:Most probably the principal factor in determining its RRP
The prefix is sold to 'big-hitters'
Posted on: 25 February 2004 by JeremyD
Has anyone compared a Stageline/Hicap with a Prefix/lesser power supply?
Posted on: 25 February 2004 by Andrew L. Weekes
Still not clear why a Supercap should do a better job than a hi-cap
Why does a Hicap sound better than a Flatcap?
The argument is the same and I doubt Naim will tell you the reasons why.
On a Prefix it is an unnecessary sledgehammer to crack a nut (from an engineering perspective), but it DOES work - very well.
Andy.
However, using just 1/7 of the supercap is like having 7 sledgehammers to crack a nut, 6 of which have no handles
LOL!
A.
Posted on: 25 February 2004 by Laurie Saunders
Still not clear why a Supercap should do a better job than a hi-cap.
Because it has a bigger/better transformer
I`m puzzled by the suggestion that only "part" of a supercap is being used in cases like a prefix. I would suggest that 99% is in fact used
Laurie S
Posted on: 26 February 2004 by Andrew L. Weekes
am just curious why given what the two units are designed to do would one be better
Simply because there is much more to PSU's, sonically, than a cursory glance at the components used or a circuit diagram can reveal.
It's a map only, it's not the world.
Andy.
Posted on: 26 February 2004 by Alan
For what is worth (long hand for those who prefer the full expression of the written English language) - (FTWPTFEOTWEL) - I recently had a home demo 552 vs my 82 (BIG jump !!) into active SNAXO/SC/250's/SBL's.
Using as source a prefix/Hicap/LP12/Ittok/Karma (rebuilt by Linn) the immediate benefit of the combination (was it the 552 gaining the benefit of the source or the source strength being revealed) but the vinyl reproduction was ecstatically enhanced. My advice - Prefix ANY LP12 and at least power the prefix with a Hicap - you won't regret it. Then add a S/cap to the prefix and let your ears be the judge.
Ken C - you are on the right track - but why did you sell your S/cap !!!
Alan
(Saving for the replacement of the 82 with a 552,
Then the 250's with 500's)
Alan
Posted on: 26 February 2004 by chfs911
I power the Prefix directly from sk 7 on the 552 and it is much better than using a Hicap. The noise floor drops considerably and the music is as close to live short of the concert hall!
By the way JTC has still not made it round yet ;O)
Posted on: 27 February 2004 by Top Cat
Charles, I thought you were in London anyway? I am free tomorrow afternoon if you are - just let me know.
John
John
Posted on: 27 February 2004 by Rico
Patrick said:
Secoonded.
Nice one, Patrick! Motion carried.
TC - buy the prefix, your LP12 will love you for it, you're certainly got a great enough cartridge for it.
MarkyL said:
Could it be something to do with the bigger toroid in the Supercap? That the S/C gets the best of the selected coils on grading? Greater number of selected parts than a hicap? Whatever the weather, don't worry about the logic of "why" - just sit back and let the music wash over you.
James wondered
Hmmm - interesting one, James. The 72 is a good step forward from the 32.5 - almost the same amp, but look at the major differences in motherboard circuit layout!? Sure there's the different filters etc. Same layout improvements apply to the prefix, amongst other aspects. We must note, that with the Prefix vs boards argument, you're not entirely comparing apples. Aside from the greater cost of manufacturing a component in a case, with cabling and terminations (all hand-made, remember), new PCB into production, the continuous R&D that goes into the prefix (the new superior RF model), the R&D that went into the careful board layout, hand-selected components... is it any wonder it costs a lot more? As you know, it's an inexpensive upgrade in the context of a great system, something that 'completes' a great LP12.
I think sometimes we forget that Naim aren't a collective, they're a company; and will price their products where they'll sell with a reasonable margin.
Oh having written this, seems I've followed the words of Patrick. Oh well, great minds and all...
Rico - SM/Mullet Audio
TC, I really think you should get a Nuno Award for your Prefix deliberations.
Secoonded.
MarkyL said:
I don't understand why a Supercap should power a Prefix any better than a Hi-cap. .... Or am I missing some black magic?
James wondered
Marky, the PrefixK and K-Boards share the same circuit and mostly identical componentry, so why is the former 5x more expensive and twice as good?
Otherwise, there is no logical reason why a pair of 135s sells for twice the price of a 250,
errr, I think the 135 pricing seemed pretty clear (the performance and market selected for the 250, the shiftup to 135 pricing straightforward).
Coil, box, R&D, amplifier module - the 250 has two amplifier channels, the 135 one amplifier channel, a big heatsink tube, fan, and thermostatic fanspeed control module. One might say "swings and roundabouts" in costs. 135's => two boxes, twice the price. I'm sure I'm missing something.
cheers!
Posted on: 27 February 2004 by Paul Ranson
I don't know how precise Naim internal costing is, but I'd be very surprised if a NAP135 cost noticeably less to make than NAP250 (old style of course).
Similarly with the crossovers, the incremental cost of the components going from 2 to 3 channels is lost in the mix of case, assembly, PCB, etc etc. A NAXO-3 might cost 1 or 2% more than a NAXO-2. Keep it simple and make the crossover price constant.
I remember that Ivor Tiefenbrun once said that Linn always priced at cost plus. I think it's the only sensible approach with something as ephemeral as hifi. (And that's also why Quad Electrostatics are such bargains, even new today.)
Paul
Paul
Posted on: 29 February 2004 by Laurie Saunders
posted Tue 24 February 04 08:42
Hi folks.
IMHO it is very well worth it.
I don`t have an LP12, though I do use a 52, and a Helikon.
Using a dedicated hicap for the prefix brings further gains, as it relieves the scap driving the 52 of extra "load"....
Pulling the k boards in the 52 brings benefit to ALL inputs
I have heard (though not tried myself) that using a scap for the prefix lifts the sound substantially.
You should easily be able to discern the above improvements with a catridge like the Helikon.
IMHO, for the gains achievable, a Prefix is very good value for money
Laurie S
Marky
It all comes down to the quality of the power supply feeding the prefix...the fact that other regulators are not being used means that the prefix has the psu in the scap "all to itself", rather than sharing it...in the same way as some 52 owners only use one source, does not make it wasteful, just because the other five inputs are not used
Laurie S
However, the mains capacitors feed 6 pairs of regulators i.e. 12 x 24V supplies. How many rails does the prefix take? I can only assume one for each channel. That makes about 17% usage,
Laurie S
Posted on: 29 February 2004 by smike42
Prefix on LP12 is definitely worth doing if it is a serious source for you. I've just had mine done and the improvements are substantial although I did add a cirkus too. I did the dem one step at a time though and its a no brainer assuming you use the turntable a reasonable amount.
Smike
Smike
