Flat Earth - But does it sound any better????
Posted by: belsizepark on 09 May 2002
Firstly I should comment that I have not done any listening tests so I appreciate that my comments below are not from first hand experience.
Some of the commentators on this board seem to view this idea of "Source First" as almost the be all and end all of building a HiFi system.
I certainly accept the argument of Garbage in - Garbage Out (GIGO) but I also believe that the sound can not be better than anything other than the weakest link in the chain.
If you have very poor quality speakers then the sound can not be better than the poor quality emitted from those speakers and the same goes for the amplifier.
To take the flat earth to the extreme, some people it would appear would like people to have the top of the range CDP combined with Nait (bottom of range amplifier) and Intro (bottom of range speaker), given a specific budget.
What if Naim introduced an even cheaper amp and speaker, then would the same apply. And whilst on that subject why stop there?.. Why not a top of the range CD player through the amp and speakers of some cheap Japanese mini system? Where does it end?
Whilst I can accept an argument that if people are on a continuous upgrade path then it may make sense financially to readjust where money is spent in order to make the most efficient changes to a top spec complete system, does the same apply if you just want to spend x amount on a system and then listen to the same thing for the next 10 years +???
This subject I am sure is quite contentious as it seems to me most people on this forum are flat earthers. i am not trying to be contentious however, I just fail to understand the argument.
If there is a report/ article someone can direct me to on the internet that shows blind listening tests etc etc that clearly point in another direction to what my instinct tells me I should be grateful to read it. Until then I must say, I am a bit of a sceptic.
Kind regards
belsizepark
Kind regards
belsizepark
Posted on: 09 May 2002 by Rico
The "Source Forst" argument has had many naysayers over the years. For all of that, many SF detractors have loudly changed camps. It is born of experience.
Michael - you really must stop reading, and start listening. One doesn't even need an open heart or mind to find a satisfying music system. Just takes those ears you are kitted out with along to a competant dealer for a dem. I would like to politely suggest that the pursuit of written arguments and evidence is akin to barking up the wrong tree IMHO. Hope this helps.
Rico - SM/Mullet Audio
Posted on: 09 May 2002 by seagull
When I bought my LP12/LVX in 83 I had a top of the range Japanese amp. It wasn't long before this was replaced by Nac42/Nap110. A vast improvement, so no a decent source with Japanese kit does NOT work!
When on the upgrade path, yes start with the source but only go for an extreme imbalance if you intend to make the next step (i.e. better pre-amp) soon otherwise you won't be getting the best out of the source and will wonder whether it was money well spent.
If I were starting now I would spend as much as I could afford on a new source (moving parts = maintenance, see recent posts on lost pucks etc.) second hand amplifiers would bring a higher specification into range as would s/h speakers. In any case, decent speakers start at a lower price than decent electronics so you don't need to spend as much on them to get a well-matched system.
A NAIT is not a poor amplifier. I don't believe that there is a 'weak link' in Naim's range, merely some products that are even better than others.
Posted on: 09 May 2002 by greeny
Got to admit I understand your confusion, and there are many(most) people who support this notion. But also many people say such things as "You have to have a 52 if you've got a CDS2" which is somewhat contary to the Source first argument.
Keep this philosophy in mind but buy what you think sounds best. Changes in power amps/speakers are often necessary due to room effects rather than requiring improved sound quality.
It's true to say that you need good quality all the way through the chain. Given this then the source first phylosophy usually applies.
PS.
Several years ago I went to change my Ittok/K18 for a Ekos/K18. After long demo's I came away with Ittok/Lyra Lydian at 1/3 the price because IMO it was miles better. OK the Lydian may not be working at full potential but it was so much better than the K18 that it overwhelmed the improvemnet the Ekos made.
PS.
Posted on: 09 May 2002 by Paul Ranson
The source first argument has always been subject to demonstration. It's up to you.
Theoretically it was predicated on the existence of good but cheap amps and speakers, originally and famously the NAD3020 and Videotone Minimax II. The argument was that this system fronted by an LP12/Rega arm/Ortofon VMS20 would outperform musically any other system fronted by a Rega 3 turntable. This was proveable by demonstration.
Don't take the idea to extremes and it works.
Of course we're assuming you want music from a hifi and not nice noises.
Paul
Paul
Posted on: 09 May 2002 by Tony L
I’m one of them.
A Nait and Intros are definitely not poor quality, fed with a decent source you would be amazed at what they are capable of delivering. Low cost, especially in the second hand market simply does not equate to low performance.
Years back Linn used to do a source first dem that (if memory serves me) comprised a LP12 / Ittok / K18 / 32.5 / Hicap / 250 / Isobariks as one system, and a P3 / Nait / Kan system as the other. By swapping the source components over everyone preferred the little system with the big source to the big system with the little source.
Things have moved on, and the major source for most people is now CD, and to my ears this opens up even more problems. Cheap CD players may sound pretty enough, but they just don’t play music – IMHO a CD3(.5) or CD5 are just about fit to listen to in this respect, the CDX is the point where it is possible to actually enjoy the experience (assuming you don’t A / B with a good record deck). So sources are now even more expensive to get a reasonable level of music out of a system - thus the front end first methodology is IMHO even more significant than ever before. I would definitely take a CDS2 / Nait 5 / Intro II system over say a CDX / 82 / 180 / Allae. Go book a dem and see if I’m right!
The digital source, amp, and speakers in my system are all second hand, so the front end bias of my spending can be ruthlessly exposed – I spent £1650 on the CDX, £165 on the Nait 2, and £200 on the Kans (the CD cost me exactly ten times more than the amp!). Ok, the Nait and Kans are both recognised as an absurdly good second hand buy, whereas the CDX has not yet depreciated enough to represent anything like the bang per buck, but you get my point. If analogue is your bag then you are in luck, you could piece together a LP12 / Ittok / Nait (1 or 2) / Kan system for less than 1k – I defy anyone to build a better value system.
Tony.
Posted on: 09 May 2002 by Dr. Exotica
A couple years ago, another member of this forum and myself tried a little flat earth experiment ourselves. Basically, we fed some very cheap speakers with a CDX/72/Hi-Cap/140 as well as a LP12/Armageddon/etc. The intent of the experiement was to compare the CDX to the LP12 using music for which we had both LP and CD versions (note - the LP12 spanked the CDX). This was all being driven into a nice set of Spendor 1/2s.
After a long and enjoyable evening comparing the two sources, I noted that I had a pair of very[/] cheap speakers in the trunk of my car - Infinity RS1s - ~$100/pair). After hooking them up to his Naim gear, we were awestruck that the true bottom of the barrel el cheapo mass market bookshelf Infinity speakers could sound so good. Not quite as good as the $2300 Spendors, but certainly [i]much more than 1/23rd as good. In fact, they were quite listenable and enjoyable in this setup.
This single evening convinced me of the undisputable merits of source-first.
Note - even though the Infinities did a good job, I prefer to spend a few extra bucks and use Tukans on my system.
Final note - Tony's LP12/Ittok/Nait/Kan 1K challenge system may be impossible to beat.
Erik
Erik
Posted on: 09 May 2002 by Mike Hanson
...to try an experiment. My main system is CDS2/52/2*135/RoydAlbion, and my office system is CambridgeCD6/72/SNAPS/110/RoydMerlin.
At some point (probably not until June), I'm going to drag the office system down into my listening room, and try swapping the CD players. We'll see if CDS2/72/SNAPS/110/Merlin beats CD6/52/2*135/Albion. I'll report back here when I get around to testing it. I'll probably have a couple of friends over to add their perspectives to the mix.
-=> Mike Hanson <=-
-=> Mike Hanson <=-
Posted on: 09 May 2002 by Jez Quigley
1. Get a mate with a top specced LP12 to make you a cassette recording of one of your well recorded faves.
2. Play it in your car/on your kids ghetto blaster
3. Go lay down and re-examine the concept of common sense.
Posted on: 09 May 2002 by Markus
Belsizepark,
There is so much to say on this topic it is hard to know where to start. Your question is a good one and you may be able to see from the responses on this thread that others have walked this path before you and come to the conclusion that Source First is essential...
But I think we have to stand back and consider a few points along the way.
What do we really mean by source first? I mean, from a practical standpoint? If you look at the systems many folks are living with (where you can actually see how they've voted with their money) you'll see that very few have actually *maxed out* their source before moving on to their preamp/power amp and speakers. If everybody on this Forum did that you'd see a lot more systems with CDX (and higher) cd sources and fully spec'd turntables feeding into Nait's and 92/90's/kans and Intro's than you do. The fact that you don't validates your principle of balancing the strengths of the links in the chain and shows that others are thinking likewise...
What you do see are systems that are the results of the vagaries of life (i.e. what was "best" when people bought what they bought, given their constraints of budget, musical priorities, domestic harmony, etc.) combined with the applications of certain Principles. Source first is a Principle but for most of us it is tempered by our personal economics and where we believe the "weak links" in our systems to be. Also, it is probably appropriate to forget the idea that price is always the most important predictor of performance. I don't mean to wander off into confusion here but what I'm trying to say is;
Many systems are composed of components which previously were regarded as "among the best" but which have since been surpassed by newer products and designs. For example, 32.5's come to mind. But knowing that a piece of equipment has been surpassed does not necessarily mean that we are going to replace it--we may be comfortable with the compromises it imposes on us or simply like it "well enough".
Most of the time we can't afford to buy what we think is the best, but we buy the best we can afford. Example, you need a new amp, would really like 135's but can only afford a used 250, then run across a great deal on a used 180. In this hypothetical situation, buying the 180 would allow funds to replace your aging cartridge which you had not planned to do but you now find yourself in a position to afford. You get the 180, replace the cartridge and find yourself satisfied for a while. When funds are next available to invest in a piece of equipment we choose to invest where we are most dissatisfied wherever that may be. It may not always be the source.
Every system is a compromise of some sort.
Upon re-reading this post I think I've wandered a bit--too many distractions and too many thoughts to express in the time I have. But I do think that if you go out and do some demo's where you can clearly compare source first systems to others that are heavy at the back end you'll end up investing proportionatly more in the front end than in the back or middle.
Markus (in too big a time-crunch at lunch time...)
Posted on: 09 May 2002 by belsizepark
But here is another few points.
Firstly I have looked at the information people on this thread have displayed and note that many people have Linn based sources and non entry level amplifiers but the CD may not be the best that Naim offer. An argument that will I am sure come back to me is that the CD is not the primary source, the LP12 is. Fair enough but in all honesty for me the Nat03 tuner gets far more listening time than the CD3.5 I own.
Secondly and i appreciate Ricos point about listening rather than reading. I am however considering going down the second hand route and I am not the sort of person to walk into a HiFi dealership get me to play various combinations of HiFi and then walk out and buy something from Loot. I therefore am trying to get as much info as I can so if i see for example a Hi-Cap or 180 power amplifier advertised or something else I might go and buy it from a seller without the benefit of cross comparisons. (My mates are not the sort who own Naim.. they all love B&O.. so can't do that either.)
Thirdly. Whilst i would would be interested to read about this Linn/Rega comparison test for the purposes of this argument I shall just accept it.
Let us consider the following - assign a mathematical percentage to the amount of pure undistorted music comes through each piece of equiptment with 100% being perfect and 0% the worse in order to try and quantify musical differences.
Now make arbitrary assumptions about the quality of equiptment used.
Linn 95%
Rega 50%
Best amp 95%
worst amp 75%
Best speakers 95%
worst speakers .75%
Then Linn, worst amp, worst speakers = 0.95 * .75 * .75 = 53.4%
c/f
Rega best amp, best speakers = 50 * .95 * .95 = 45.1%
I have just made up numbers here to demonstrate a point, but in the first case with the Linn based system because the net musical output is higher than the output of the rega before any further parts of the system, the Linn will always win.
By constructing a more balanced approach then you can increase the final number. This itself can be mathematically proved as x squared is always greater than (x+y)(x-y) assuming y is not zero.
what I mean is that you have a choice of musical output of say 75% from CD and 75% from amp this will result in a higher number than 80% from CD and 70% from amp.
Now I have no clue if I am making fair numerical assumptions about what can be heard but i hope that you see my point. It seems to me that if the absolute pick up in additional quality for a given amount of money to spend is higher on one component than anther then maybe that should be where the money is spent.
Is for example the extra £1320 spent on a CDX as compared to a CD5 better spent than spending that extra cash on a 102/180 pre power combo as opposed to a Nait?
So that is my dilemma.. improving my system from cd3.5/92r/90.3/credos and nat03 , brand new I could afford to purchase say a hicap for the 3.5 or a 180 and trade in the 90.3 or second hand I may have the luxury of being able to afford both the hicap and 180. When i got some more cash I was thinking of upgrading the 92r after that possibly by adding a hicap or maybe by trading in for a better model. I can not really afford to do so at the moment .. but do people think if I am going to upgrade on the source first argument i should wait till I can afford to switch to a CDX and just do that because I will never regret it and it will be much better than playing around with amps?
so many questions..
Thank you again for help so far...
Belsizepark
Belsizepark
Linn 95%
Rega 50%
Best amp 95%
worst amp 75%
Best speakers 95%
worst speakers .75%
c/f
so many questions..
Belsizepark
Belsizepark
Posted on: 09 May 2002 by MarkEJ
Definitely, IMHO.
1. When I bought my current turntable (Heybrook TT2), I ran it through a fat Trio amp and Bose 301 speakers. If I had saved for another couple of months, I could have bought an LP12, and would consequently have a better system now. "No" (I thought), "keep it reasonably balanced". Complete bollocks -- should have hung on for the LP12 -- the biggest buying mistake I've ever made, and all basically through impatience. The more components you have which aren't maxed, the more changes you will have to make to get to a certain level, and the more money you will ultimately spend getting there. Don't make the same mistake!
2. Until you actually try something like LP12 into ghetto blaster, versus ghetto blaster into [your personal fave amp/speaker combination], you will never appeciate, or even begin to believe, how darned good 99.999% of all loudspeakers ever made are at the musical fundamentals which allow us to enjoy listening. Feed them nicely, and they'll let you know. Feed them crap and you won't immediately think "Crap", but you'll gradually start to watch more TV. That's how it happens!
Best;
Mark
(an imperfect
forum environment is
better than none)
It doesn't work that way.
The only way you can decide what your upgrade path should be is by demonstration. It may be that you have a large room and like to play loud so an amp upgrade would be helpful in avoiding clipping. Anything clipped is 0%.
Paul
Paul
Posted on: 09 May 2002 by Andrew Randle
c/f
This looks familiar
You're on the right lines here. It is a COMMON MISCONCEPTION that a system is simply as good as the weakest link. An amp or loudspeakers do not have a hard-defined ceiling that limits the performance of the whole system... just whack on a better source and it still sounds better.
Andrew
Andrew Randle
Currently in the "Linn Binn"
Agree absolutely.
Good to see you're doing research with the patented search bicycle, Michael. You will find amongst the archives many tales of woe recounted by those who've walked themselves out along the plank with each successive upgrade until they realise they're not listening to the system very much anymore. They end up throwing more and more money at the system attepting to rebalance or redress problems.
If you are really concerned about funding etc the luxury of an in-depth demo with a good dealer, and the subsequent purchase of CDX from said dealer will likely save you much money and heartache.
You can't buy a satisfying music system by statistical means.
Look. Let's be reasonable. Who among us, if we owned a 3.5/92/90/whatever system would not buy a different amp/preamp/power supply/ whatever if a good deal on the used market came along vs. going into a dealer and spending full ticket on a brand-new CDX? The question isn't what is the better cd player or even what is the better system. It's a question of value for money. And it's not even a question of "should I or shouldn't I". If you set your sights on a CDSII/52/500/DBL system then everything between here and there is a stepping stone along the way.
Look at the weak links in the system. The "intermediate" Naim levels are the remedy to those weak links. You don't have to go out and go crazy with a CDSII before upgrading the 92/20...
Markus
Markus
Posted on: 10 May 2002 by plynnplynn
I fear that there is a tendency for some of the more frequent contributors to the Forum to take extreme stances on certain issues. The 'source first' dicussion is one such issue.
When discussed this invariably revolves round equipment - record decks, CD players, pre-amps etc.
Very few of us will disagree with the wisdom of getting the best source and most of us agree that speakers always seem to have that bit more to offer if the information is there in the first place.
To confirm this I did a completely unscientific experiment with some Ross wireless speakers just today (I have 4 of them). I carry them about the house as required and I deposit them at various points. eg when I want to listen to music in the garage or the shed I take a Ross with me. The signal to the transmitter comes from the pre-amp of my main Naim system (at the moment a modest Rega3/CD3.5/32.5/250). This gives me music anywhere. If, however, I really want to concentrate on the music I sit down and listen to the music through my main speakers.
Today I put a Ross speaker on top of each of my main speakers (set them to stereo), switched back and forth between the main speakers and the Ross speakers. The quality from these plasticy, £70 a shot, peripatetic speakers amazed me. I don't think that I had ever listened to them seriously before. I suspect it was an example of the Ross getting a reasonably good signal (source first argument) and being able to respond. What I am trying to say is that I believe all you guys who say that the front end is the place to start and what comes after that may produce results which will surprise.
What I also wish to say however is that there is more to the rationale for what individuals should buy than this front-end first argument.
There are pragmatic issues like good deals becoming available (mentioned above); what can be afforded at any time - eg upgrade in a manageable cost aware fashion to keep the enthusiasm going, even though a more sensible upgrade could be made in 6 months, if a bit more careful personal saving takes place. It is after all a hobby. It is not a life or death issue. Sometimes we are not logical in our decision making. We buy something for the feel-good factor.
I am not going to leave the source first issue without some further comment however because the source first zealots should ask themselves the following question.
What change/upgrade made the biggest difference to my system?
From my modest position I cannot perhaps comment too much about what there is still left for me to achieve but I do know that the two biggest differences made to my system had nothing to do with source. I am talking difference here. Relative improvement!
In 1976 I moved into what I thought was then the bottom rung of home hifi. It was all I could afford. Approx £100 per item. Garrard Zero 100 deck with Tangential Tracking Arm, Leak Tuner, Sony Cassette Deck, Rotel Integrated Amp, Second Hand Sony Reel to Reel Tape (this was the best source) and I made my speakers (KEFKIT3 - based on the KEF Concerto of the time). I was a happy boy.
1990 - with family growing and a little money to spend I bought a Rega Planar 3/K9. Great improvement over Garrard.
1996 or so I bought the first CD player I heard that I could bear to listen to and I could afford (Micromega £550). It gave me something like the quality I got from the Rega.
1998 I bought Nait 3. Good improvement over the Rotel.
1998 and a few moths after buying the Nait I purchased NACA5. I couldn't believe the difference. A veil was lifted.
1998/9 or so I upgraded my speakers - new crossovers, new tweeters, new internal wiring. Good improvement.
2000 or so I built spikes into the base of the speakers and made a plinth out of concrete slabs and wood. I couldn't believe the difference. Another veil was lifted from the sound.
Since then I have bought 250 with 32.5 thrown in - a bargain appeared and I bought it - it was not planned. I have also bought a HiCap (again bargain - not planned) and a couple of Flatcaps.
Various experiments followed as you might expect with Flatcaps, HiCaps, CD3.5, Nait 3, 250. I concluded that the best combination for me was CD3.5/Flatcap; 32.5/HiCap; 250. I did however continue to love and admire the Nait 3 sound. The current system is however better - I won't say what I prefer about it as that is nothing to do with this post. What I will say is that the difference between any of the combinations of the above did not match the difference I experienced when I started using NACA5 and when I sorted out the bases of my speakers.
Source first is clearly a fact! Relative difference may however also be an important concept for anyone to consider when upgrading. The concept of relative difference may well be as important for anyone who cannot just go out and buy to a plan for pragmatic financial reasons. What I am saying is upgrade from where you are to make the maximum difference. This may not mean looking at the source.
It is my intention to be more 'source first aware' from this point on and purchase CDX and then 82 with suitable improvements in power supplies.
Oh I forgot that is not all I am doing. I have deigned myself a stand and I am going to have this modular wonder built partly by a blacksmith and partly by me. I am also going the 10mm separate spur route (4 or more) with dedicated consumer unit, 15 amp plugs and sockets and 10Amp bussman fuses in equipment.
I suppose that the mains improvement is clearly source first and it could be said that the stand is also source first.
I suspect (but don't know) that the greatest relative difference may not come from the most expensive of these upgrades - the equipment (82 and CDX and power supplies)!!!!
The concept of relative difference could thus be replaced or 'upgraded' to the concept of ' cost effective relative difference' in my eyes as the most important consideration for people when upgrading their systems.
In conclusion I feel that it is generally overly simplistic to talk 'source first' . Other issues must be considered.
Terry
Terry
Posted on: 13 May 2002 by Johns Naim
An interesting thread, and quite informative, ringing a few 'bells' with me. In principle, I agree with the source first approach, but also I think that how one approaches system building, or upgrading depends on what you want out of it now, and in the future, which I suppose very much depends on what one can do, or plan to do from the point of financial expenditure.
My first Naim purchase was a CD Player. I wanted to get a CD player, so as to have access to further recordings of choice, but the bottom line was that it had to equal or better my turntable in terms of performance, as otherwise I couldn't see much point. After a lot of auditioning, different brands etc, I settled on (at the time) the CDI. The CD3 was good, and the CDS a lot better, but I felt I could live very happily with the CDI, AND, I was also thinking about replacing an elderly, but much loved amp, and depending on results, possibly even equally elderly but much loved speakers, so was mindful of both the front end first approach as well as the 'balanced' approach, and my overall budget.
As an example of excellent service, AV Excellence, the local Naim dealer, came around and took my entire existing system to their store (my being carless at the time) and spent an afternoon/evening trying out various combinations.
It became quickly obvious that it was time for a new amp and speakers as well. I was at the point of only really wanting/able to spend Nait money, but just was not as quite as contented with the sound as going further up the line. All the equipment was played for me, and I decided on the then 72. It had a lot more detail, and was of a higher performance level than the then 92. Yes, the 82 was a lot better again, BUT I was also thinking of amp and speakers, and the budget that I had, and for the foreseeable future.
In the end, I settled on a 180. There were only very subtle differences between it and the 140, and a much bigger jump to a 250, but in my opinion, and also advice of the dealer, I went with the 180 to allow greater flexibility for speakers "later on" for as much as I wanted speakers then and there, had spent my budget.
Eighteen months later I went serious new speaker hunting, and became very enamoured of Epos 14's and still am. However, with them at home, the one thing that let them down, for MY taste, was relative lack of bass extension, and power, compared to my current speakers at the time, a pair of early B&W designs. I listen to a lot of baroque music, and am a huge fan of pipe organ. One can argue to the cows come home about PRAT etc, all very relevant agreed, but, if a speaker can't get down to 30HZ or below, then it's going to fail to reproduce musical notes that exist on the recording. A 32ft Organ stop has a fundemental resonance of 16HZ,with harmonics at 32, 64HZ etc. Hence small bookshelf speakers, limited to around 50HZ or so, only reproduce the upper harmonics, and hence a facsimile of the sound, so they were out.
To cut a long story (auditioning!
) out, I settled on SBL's. For the sort of music (organ) that I often like to listen to, and the power required, I simply couldn't have achieved the desired result had I gone for example, CDS, 82, 140. Partly budget (wouldn't have been able to afford SBL's) and bottom line 140 was at or beyond it's limits fairly often when auditioned, v's the 180 with the SBL's on the program content of my choice, and at realistic (pipe organ
) levels.
This of course (doesn't it always! ) meant I had to spend more, and save up for a Hi-Cap which was added a little later. So I've probably broken all the 'rules' of system building, but, it gave me what I wanted, which was a system that achieved an overall level of musical performance 'excellence' such that I could be very happy with it for a long period of time, without needing, or having that nagging feeling of 'having to upgrade'
It's hard to believe it's nearly seven years ago; the equipment looks and runs like new, the dealers have become friends, and I'm so grateful for the service and advice they offered; nothing was to much trouble, and believe me, I'm one fussy person when it comes to sound, and, (like most of us) the spending of hard earned.
The system is well balanced; not so much in either the front end first, or speakers first approach which used to be contemporary thought many years ago, but in the music making, and enormously satisfying and pleasurable results it gives across a wide variety of music. ( I listen to Jazz, electronic, film, techno-ambient etc, as well as classical) and whilst I readily appreciate it's limitations, like all hifi systems, it's a joy to listen to and to use. One day, if finances ever permit, I'll upgrade, but, for what I wanted, it's my perfect dream system, and I love it.
And, if doing it all over again, no, I wouldn't build it differently. (Hey, I just love those Bach Organ Works, and that subtle room filling 'Purr' of a 16' organ stop - 32HZ resonant frequency - and the occassional door rattle - puts me right in the cathedral!)
At the end of the day, all I could say is find an excellent dealer, and spend some time and let YOUR ears, and musical tastes be the final arbiter. Dogma can lead to headaches, but a love of music will always satisfy. Let your ears, and your heart enter the decision as well as your head and your wallet.
Good luck with it, and thanks for starting off such an interesting thread.
John
Music is the Naim of the Game
John
Posted on: 13 May 2002 by Rico
The CDX is better value for money. Clear pure, and simple. You may not have been on the forum back then - but I went through [many of] the intermediate steps along the way... opportunist preamp upgrades, power amp upgrades, yeah, they were all sort of fun. But given the question of "how best improve my system?" [read: more music wanted] - the CDX is the answer. Given the experience I have, and another opportunity - I'd buy the CDX every time. It's not the only answer, but the most appropriate answer [other CD manufacturers ignored for brevity]. Please note that the question is not "how might I have an enjoyable path from A-B with the most circuitous journey"! : )
Without the luxury (luxury you CAN afford, folks!) of a dem to address such issues as room fill, system synergy etc, source improvment should take even greater precidence.
Sorry - not extreme. Most of the regular posters have "been there, done that, got the t-shirt" - and rather than tiredly posting in a humourless manner, are still enthusiastic about answering a call for advice, from someone embarking on the same journey. These people are keeping the faith! And are keen to help.
Shit, someone here once said "buy the 250". He was right.
Posted on: 13 May 2002 by plynnplynn
Without any doubt the less experienced members of the Forum appreciate the input from the long serving members. Much is learned from their posts and their input is read with interest.
But the Forum will only prosper through involvement and interest from new members and new members' posts will inevitably cover areas which have been dealt with previously.
Terry
Terry
Posted on: 13 May 2002 by Ron The Mon
While shopping recently with a female companion, I got bored and strolled into the "Bose" outlet shop(I was really bored). After many years of hearing how bad Bose sounded in peoples homes (I actually lived with a cousin for a short while and his Acoustimass set-up was pure crap) I was surprised to hear some great music eminating from a distant room. When I went in it was a fake kitchen with a Bose Wave Radio on the counter. I was floored. It sounded fantastic. I couldn't believe a Bose CD player could sound so good. Upon closer inspection I noticed the CD door was permanently glued shut! Then I knew something was up! As I changed radio staions, I noticed every station was playing only music, all instrumental with no announcers. I looked on the back and a thick coax cable was hardwired to the inside of the unit. When an older couple entered the room commenting on the outragously good sound, I tried explaining how it was all a source-first gimmick and it wouldn't sound as good at home. The gentleman said I should be aware that speakers are the most important component and Bose makes the best. At that point a salesman rudely asked me to leave the store after I demanded to know where the mystery coax went to.
So remember Source-First works even on speakers and amps as low-quality as a Bose table top amp and speakers!!!
(as an aside the room was also literally "single-speaker demo")
My recommendation to Belsizepark is to trade-up from NAT03 to NAT01 or NAT101 (and a top-notch antenna). I have heard a NAT01 into a 32/90 and it was mind blowingly good. For comparison I then hooked up an NAD tuner to a 32/hicap/250 and it wasn't even close. If FM is your most played source, then the tuner(and aerial) is the place to start.
Ron The Mon,
Arch Kan defender and wall driller.
Ron The Mon,
Posted on: 14 May 2002 by Stephen H
I've always upgraded source first, but if I'm honest, I've always noticed more change in my system when replacing the amps.
I started off with a Dual 505 deluxe, Marantz PM151 (dirt cheap and sounding better than it had any right to), and Mission 70Mk11. When I was lucky enough to win a Linn Axis in the New Hi-Fi Sound comp, I was really looking forward to a quantum leap in performance. Sure, the difference was noticeable, but it wasn't earth shattering. I quickly sold the Dual t/t and amp to fund an amplifier upgrade to a Musical Fidelity B1. Result! I could now hear what the Axis was doing better than the Dual.
Similar story when I got the Sondek, but the step up from the Axis was quite significant even through the B1. When I got the 72/140 back in February the improvement was IMHO a much bigger step up than the change of t/t.
Since I was never in a position to do the A/B comparisons of all the kit along the way, unfortunately I can't really be sure how the ratio of perceived 'total' improvement splits between source and amps.
For example, suppose my total improvement was 100% on my original sound.
By going source first did I get something like
25% improvement on change of source
35% extra improvement of source 'revealed' with new amp
40% improvement due to new amp itself
or was it really that the amps contributed more of the whole than the source?
All I can say with any certainty is that I enjoy the music more at each stage, so at the end of the day I just upgrade as the opportunity strikes.
Steve.
Steve.
Posted on: 15 May 2002 by Johns Naim
Hi Steven,
Interesting thoughts and experiences. I tend to agree with the source first principle, however, I've also noticed when auditioning, that changing different components within a Naim system brings slightly different, although similar results.
It can then become difficult to decide sometimes, which is the best component to change given one's budget, and where your'e wanting to go in the systems development.
Usually I think ones ears and a really good demo is the best way here.
I'm going to be facing the same dilema sometime in the future when I can afford to upgrade; it'll either be an 82, or a 250. Interestingly, despite the source first approach, my dealer advocates changing my 180 for a 250, over the 72 to an 82; reason being that it will in their opinion give the best result for the money given I'm using SBL's which they say really need an 250 to perform somewhere near approaching an optimum.
Obviously, active, 135's etc even better, but, ahem, $$$
I heard all the combinations when I bought the SBL's, and I felt that a 180 was pretty much the minimum amplification required; the 140 could cut it, but not really that well, at least on the sort of music I'm prone to listen to, and the 250 was a lot better than the 180 on those speakers, but unfortunately out of my price range at the time.
Certainly, in the context of my system, having heard the combinations, despite agreeing with the source first approach, thought the 250 made better music overall, versus the 72/82 as mentioned.
Anyway, it's really a very interesting subject, but a hard one; I'm not sure that there's always a hard and fast rule, use ones ears as best one can I guess.
Thanks for your thoughts,
John
John
Posted on: 15 May 2002 by Andrew Randle
Ron,
About a year ago I went into a flagship Bose store in Singapore. They were running free demos of an AV home system.
Surprise surprise, they were showing a excerpt from Gladiator. Let me tell you how bad the timing was --- the speech was slurred !!!!
Andrew
Andrew Randle
Andrew
Andrew Randle
Posted on: 16 May 2002 by belsizepark
Sue,
Is it just a coincidence that you are thinking of replacing your Naim equiptment with non Naim equiptment shortly after a Naim dealer, where you are married to someone closely connected to it - haslost its right to distribute Naim products?
Are Audio works dealers of Accuphase and Rega products?
Shirley not????
Belsizepark
Shirley not????
Belsizepark
Posted on: 16 May 2002 by Craig B
Do you not have a nearby bridge that needs trolling?
Craig
Arch Naim defender and troll driller
Craig
