Output from an imac - need help please
Posted by: Lee Henley on 04 April 2010
I hooked my imac upto my Dacmagic yesterday for the first time to give it a bit of a play, the dacmagic tells you what the incoming bit rate is via front LED's. I played a track on the mac which had been converted at 48kHz but when I played it back it only came in at 44.1 kHz, how does one get the mac to play at higher rates through a DAC. I used an optical cable out of the headphone socket via a mini toslink converter.
Any help much appreciated
Lee
Posted on: 04 April 2010 by garyi
Goto applications>utilities and open Audio Midi Utility.
Posted on: 04 April 2010 by Lee Henley
Cheers, just had a look at it the Utility and it seems straight forward to configure. Can you leave the digital out set at 96kHz,or do you have to change it for every type of bit rate that is going to be played?
Lee
Posted on: 04 April 2010 by T38.45
Hi Lee,
i'm not an expert but i think you need for fixing this a SW like Amarra!
Amarra matches automatically and improves sound.
Ralf
The Amarra looks a nice piece of kit but at $995 I will give it a miss, its a bit out of my price league unfortunately but thanks for the heads up
Posted on: 04 April 2010 by Joe Bibb
Have a look at Pure Music, does the same only much cheaper.
Joe
Posted on: 04 April 2010 by winkyincanada
Joe
Can't say that I was impressed with Pure Music. You can download a trial version for free, though.
Just out of curiosity what is wrong with itunes?
Nothing, its a great app.
Nothing, you seemed interested in automatic bit/sample rate changing - iTunes won't do that.
Joe
Joe
You haven't got it working? It's very good.
Joe
Joe
Joe
It sort-of works for me, but I just can't hear the difference. The other issue is that it would only play one track at a time. Useless. Bought CDs instead.
Don't blame you, fortunately it works fine here and is a considerable improvement sonically.
Joe
