Totem model 1 placement
Posted by: jho on 29 July 2002
Anyone using this speaker. Can advise me on the placement of the speakers? I am placing it against a straight wall. Using a 24" height stand. Feels somehow a bit lack in bass.
Posted on: 29 July 2002 by Peter Stockwell
try this software for postioning speakers ...
CARA
Have fun!
Peter
Posted on: 29 July 2002 by Phil Barry
I believe the Totem 1 is designed for free space placement, away from walls.
What happens to the bass if you move your position of the speakers? It could be that you're in a null. Or you may not like (this) mini-monitor(s).
Phil
Posted on: 29 July 2002 by Manu
As a general rule, you should place them at least 1.5 feet away from the rear wall and 2 or 3 feet from side walls. Bass and soundstage will improve.
Of course, you have to experiment, each room has its particularity.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
