Balanced Power:The thrill and pain of installing your very own electric substation
Posted by: Onthlam on 18 June 2005
This thread is intended to communicate my journey from first thought to making the decision to buy and install the product choice I made.
It is not my intention to go against any forum rules and would appreciate anyone who decides to add to the dicussion respects this wish.
There is,I believe, a great learning here(at least for me)and would like to get this into the minds of others who have the same issues with mains that I have/had.To allow those who have never had the chance or reason to believe that there are options out there(including me). Options that could possibly be the holistic resolution to your barriers from enjoying your Naim system.
Forget about doing things that might burn down your house. Everything I will tell you about is legal here in the states and in the U.K.
Some time ago there were a few threads that talked about the use of hydras and mains conditioners.
I was very interested as I have always thought that the Naim product is perfect when it leaves the factory and I/we screw it up when we get it home.
The last 10/11 monthes I have tried to minimize the effect my room,floor,and setup has on the quality of the music.To that point(for those who know and have seen the amount of work)it has been insane...
Redoing the Fraim 3 times to get it right.
9 floor jacks to minimize the effects of my horrible floor.Corian,porcelan lifts,SB3s,hockey pucks and a 16 foot span attached to the ceiling(garage)to dampen the floor of vibrations.
I can honestly say at the end of the day the kit sounds very good most of the time,great some of the time,and perfect came in the form of a 2 week period in April.
It sounded so good I was afraid to go to the restroom! Afraid that when I came back the conditions would have changed. The music was So emotional,harmonic,pitch perfect,and dynamic I did not want to go to work and when I did I could not wait to get home. Like I mentioned this only lasted for about 2 weeks and it was gone.
Why?
The weather was different than normal.The temp should have been in the 80s or 90s but ended up in the high 60s to the low to mid 70s.
No ac or heat.No pools on and it was for some a school holiday and folks were out of town.
The mains was quiet,very quiet. In all the years of living in California this had never happened before.
Not knowing what to do and where to turn was very frustrating.
Started reading everything I could get my hands on. Everything about ac/dc,conditioning,regeneration,surge protection,and gfci products for home and studio use. Some should remember that I was willing to get my own generator for the kit. This turned out to be not only a bad idea but the worst one of all.
It was by chance that I called NANA one morning and Dave Dever answered the phone. Dave had mentioned a product that he had used in his previous life that worked well in the studio.I had read a bunch of white paper and reviews on the use of balanced power but was still not convinced that this was the way to go.
As most products utilize current limiting designs(no matter what they said)I was not up for finding out for myself that this was true.
I ended up calling my electric company. I asked them if I could install a second meter and dedicated service to the house. I was told that a second meter could not be done and the limit for a single familt home was 320 amps total.
The electric company was willing to put a recorder on my meter to measure harmonics and voltage fluctuations.On that day it was our oldest daughters birthday. Hair driers were a blaze and the 3 girls were going to have nothing to do with the electric company shutting off the power for even a minute.Sucks to be me situation.....
Told them to look at it again after the 17th of the month.
Bottom line here is that It was legal a few years ago to put in the second meter. This is what I was to do when we were building our house. I was shy because of the cost and that was that.....
I was looking for a product that could supply more than enough current(at will with speed) with no gfci,regeneration,or any conditioning what so ever.
More reading and a couple of more calls to Dave put me in the direction I thought would give me the best bang for the buck.
Balanced power is as follows:
When 120-volt AC power is balanced, one side of the circuit has +60 Volts to ground while the other has -60 Volts to ground. (Across the circuit, the usual 120 Volts is still present. A European 230 Volt balanced power system has +115 Volts and -115 Volts to ground on the conductors.
Standard unbalanced AC power systems have a "hot" conductor and a "neutral" conductor. In the US, the "hot" conductor nominally has 120 Volts to ground and the "neutral" conductor has 0 Volts to ground. Europe has a similar system but with 230 volts on the "hot" and 0 Volts on the "neutral."
In a balanced power system, the voltages on the system's two output terminals are 180 degrees out of phase to each other with respect to ground. The system reference (ground) originates at the output center tap of an AC isolation transformer. In other words, the system's grounding reference (zero position) is located at the system's mean voltage differential or zero crossing point of the AC sinewave. This is a far more effective way to establish a reference potential for an AC system. The center tap is then grounded to Earth for electrical safety and for referencing shields.
There is never any voltage or current present on the ground reference in a balanced power system. Transient voltages and reactive currents which normally would appear on the neutral and ground wires are also out of phase and likewise, sum to zero at the ground reference thereby canceling out AC hum and noise.
A balanced AC Power system works the same way as a balanced audio circuit but with a higher amplitude. Both balanced audio and balanced AC incorporate phase cancellation or common mode rejection to eliminate noise.
I decided to contact a company that only makes balanced power systems. These folks were very helpfull on many different levels. They make boxes for in the house as well as sytems for the largest and most critical needs for todays space program. The list of studios and artists that utilize their products is simply a "whos Who" in the music,stage,and recording industry.
More phone calls to figure size and configuration. I was able to get a 10Kva transformer in a NEMA 12 box. This is a transformer that will provide a 100 amps and can run all day at 85 amps. Again with no gfci.There is no gfci device for anything over a 20 amp circuit(mine is 40).Nothing to limit the amount of current that the kit would need at any given moment was installed. The in house boxes come with some of these devices. I was staying away.
Who to install this 325 pound beast?
My family and I went up to Oregon to fetch this thing. The back of my car lowered 5 inches as the lift lowered it onto the cargo area. What am I getting myself into!? I was able to get a material lift (to rent) for a day and spent the day before reinforceing the area in the garage the box would sit on. More lag bolts and angle iron than I have thought would be used to erect most large kiddy play sets was used. It was hot and I had my doubts. Blew up one of the Dewalt 18 volt batteries in the process. Not happy...
A week before this work I was able to speak to the most experienced of all installers. He had made it clear that any sparky could do the job. I called mine and was ready to set up a time for him to come in. I had met him at my place of business and just did not feal great about the potential for success. I called Barry back in lovely southern California."Barry, I need you to install this thing.Everyone has said you have the experience and the track record that will insure the best sound."
I flew him in and off to the house to get it juiced up.
Took 7 to 8 hours to get it done and the power was on.
There is a 30 day money back on all of their products. Thank God!!
I was not happy at all. Everything was dull and compressed. The music was nothing like it was before we started.
I was told that this is common. The transformer needs to run in and stabilize.My take away was to walk away for a couple of days and then make a go at it.
After three days the sound had improved a bunch.Very harmonic,pitch was greatly inproved,and the timeing had improved (that small amount that always got on my nerves.)
There was something still very wrong. With all the benefits there was a sence of dynamic supression. What! A 100 amp system does not have the speed to supply a 2 channel hi-fi current?!
Kuma-This is where your words on the forum played a huge part.
I remember a discussion about the amount of damping on ringing boxes. That the more you put on-the more you may dull the sound. I have been on the hockey puck band wagon for a while now and have loved the effects...
Today I was about to give up when I remembered Kumas words and took off the pucks and replaced them with much smaller(less mass)items.
Holy SHITE!!! What a difference. Had everything else but now I have the dynamics and the speed!!!! I am out of my mind happy....Marc- Calm down and listen. Listen more. Listen even more.
The high end is not described as sweet or harsh. I would describe it as cymbals and triangle. the Bass is not fat, it is a Bass guitar. The vocals-WOW!
This work has been (to this point) the most important upgrade I have ever done. Not saying it will be great tomorrow but if it continues to run in for the next 30 or so days(as they have stated)it will be amazing. I did ask for a 45 day return policy and I was obliged.
The cost at retail for the device I bought was less than a SuperCap!
As much as I was in the camp of nothing will fix this? As much as I was in line with those who believed that there is no device worthy of Naim kit?
I now believe that the "source first" mindset begins with the mains. Clean this up,fix everything else you can and hope for the best.
For me it was a huge leap of faith. I am glad that it worked out. Still, lets see what happens in the near future.
I have not mentioned the name of the brand on purpose.If you have any interest? Please email me at closedmail@comcast.net
Pictures to follow.
Best to all,
Marc
Posted on: 18 June 2005 by Onthlam
Picture 1
picture 2
picture 3
picture 4
picture 5
Posted on: 18 June 2005 by Derek Wright
Marc -
Interesting information -
does this new device give you any protection from lightning strikes on the overhead mains cables
what are the "hockey pucks " you talk of.
Derek-
All of the mains in this town are buried underground.
A hockey puck is the one used in the NHL.
That thing that is slapped to 108 mph at the goalie.
Posted on: 18 June 2005 by Geoff P
Marc
I think you need to explain about how you use the Hockey Pucks, for those that have'nt seen them in operation.
How many spurs are you running off this beast?
Geoff
Geoff
The next time you are in town???
Gabrielle should not slice and dice.
The hockey pucks are a simple thing. I ordered them from a sports store in Chicago. In Ca. there seems to be a lack of hockey play and ice rinks...
Until today I used 1 on the top of the 552 and 1 on top of the CDS3.
The 552 would be placed on the first third of the top in the center. The CDS3- I placed this 1 at the right rear corner.
The effect(hope)was to minimize the microphonics and ringing(if on top of a ps.)
It worked very well but with the transformer the damping was to much. I replaced the pucks with porcelain electric fence isolators. This has proven to be just enough damping...
I am using 1 40 amp dedicated spur to a 40 amp hubble twist lock(wiremold). With the chance of moving homes, I did not want to invest in long lengthes of JPS ac wire and the custom switchgear.
Marc
Posted on: 18 June 2005 by Exiled Highlander
Marc
I am in awe....you are one serious dude when it comes to maximising your hi-fi, but with the investment you made and the extension of the source first principle (mains power supply) I can't argue with the logic (or your results so far) of the approach!
Jim
Posted on: 18 June 2005 by dave simpson
Marc,
Ever consider hardwiring the Wiremold to it's AC run once you've settled-in somewhere?
regards,
dave
Jim-
It's all about the music.Thanks....
Dave-
I was talking to Barry(installer)about this the other day. Solder the wires together is going to be the trick,we think?
The down side would be when I need to unplug the system.Storms jump the power switches...
More thought, more ideas.....
Still-A great idea..
Thanks....
Marc,
Eliminating that one extra connection can be quite shocking. FWIW, I soldered my dedicated AC line's 6 guage wire to the Wiremold's 12 (?) guage cord without any problems using a decent iron. I then used appropriate-sized wirenuts and a final wrap of electrical tape before sealing them up in the wall's junction box. If I recall correctly, I used a 1/2" drill bit to enlarge the small hole in a switch-plate cover for the Wiremold's AC cord to exit. Oh yeah....don't forget to thread the switch-plate cover on the Wiremold's AC cord before you solder and join the two cables ;-)
Try to reposition the Wiremold behind something existing or new (sculpture, painting leaning against wall, etc) for easy access to the system's AC plugs when storms approach. I know it's a pain, but I believe you'll find it worth the hassle.
regards,
dave
Dave-
Can we take this wiremold topic to email?
Marc
By all means.. blackdogaudio@triad.rr.com. If I don't get back to you tonight--the wife is feeling a bit frisky--I'll get back with you early tomorrow AM.
best,
dave
....and this was all going so well too....Padded Cell beckons now (at least) I guess.....
Jim
Posted on: 18 June 2005 by Adam Meredith
Nope.
Good decision Adam!
What the hell are you doing up at 4.15am though?
Jim
Posted on: 19 June 2005 by kuma
Geoff,
I use training hocky pucks ( sponge type. Not the hard ones ). Heavier they get, the music gets choked so you don't want to overuse them.
Start with just one. Then add if you think you need a dampening. I use just one on all boxes except the CDS3 and two on the 552 PS. One near the DIN sockets. Another on the center. Adjusted by ears.
Gees. this is really a tweeky s**t, isn't it? Roll Eyes
Posted on: 19 June 2005 by Derek Wright
Thanks sports fans for explaining the use of hockey pucks - I was having great difficulty in visualising one on top of the CD in a CDS3 - but then having heard of Marc Newmans dedication I thought that he perhaps had a special cathedral roof lid for the CDS3 installed.
But back to the storm issue - you still are at risk from lightning surges just as much as you were before.
Posted on: 19 June 2005 by Geoff P
Geoff,I use training hocky pucks ( sponge type. Not the hard ones ). Heavier they get, the music gets choked so you don't want to overuse them.
Kuma...I thought it was just Marc but now I am worried this could start something.
Of course over here we don't go in for hockey pucks much so I can sse folks having to experiment with other items. I have this vision of CDS3's with half empty Jam jars or mini cans of baked beans sitting on them. Then people will start discussing how much jam to leave in the jars etc.
Sorry....Marc & Kuma, I am sure the sonic benefits are genuine I just could'nt resist. Big Grin Big Grin Big Grin
Geoff,
Well, putting some weight on top of a component is not a new thing for me.
Except this time, observing a low mass concept. I used to do the opposite. i.e. putting a 50lb. worth of lead shot bag over underdamped CDP. Razz
I'm sure that Naim designed the chassis not to overdamp and ringing is probably intentional. ( otherwise, they would put damping strips )
The tweaks are not a *must* items but in certain cases/situations, they can come in handy.
Nonetheless, I know this is 'anoraky' ( hello JonR!) activity and at least I don't lift cables off the floor with cable lifters. ( this is where I draw a line. ) Winker
Marc does'nt draw the line.....ANYWHERE!!! Eek Big Grin Cool
Posted on: 19 June 2005 by Onthlam
Derek-
There is nothing that I know of. Like everyone else,during a heavy storm I am running to the kit to get it turned off and then unplugged.
The surge potential is limited with inground utilities. The last storm caused my S3 to spin and none of the controls worked. Had to shut it down and restart the thing for it to work...
Learned a great lesson...
Marc
Kuma-
I would not call it tweaky at all.Naim provided a balance that allows us to make it real in the field.The key is(in my mind)to recognize the opportunity and do something about it(as you have).....Read your post again.You said the same thing.
"The tweaks are not a *must* items but in certain cases/situations, they can come in handy."
The reason for the cable lifters-
I have carpet over my floors. This carries a low charge of static and messes up the flow in the A5. Once the A5 is up, it takes about 2 to 3 days to dissipate the charge. I went back on this one a couple times.If left alone-Giving the cable a chance to release this energy, it does help(IMHO).
Posted on: 20 June 2005 by Dev B
Dave Smile
My wife was too, but I fell asleep Winker
Dev
