250 warm up
Posted by: syd on 20 January 2003
Hi All
Would it be OK to connect a Nap 250 to the mains without it being connected to the system. I would like to check that it is working ie. light coming on etc. or could this damage it. It was delivered this morning and has been in transit via Parcel Force since Thursday. I've removed it from the box and left it lying on a table to acclimatise it to my room. I was worried that the cold and damp may affect it if I powered it on right away.
Yours in Music
Syd
Posted on: 20 January 2003 by NB
Hi Syd
There shouldn't be a problem as its not connected to anything. You have already done the sensible thing by making sure there is no dampness in it.
NB
Posted on: 20 January 2003 by syd
Thanks NB
I left it for a couple of hours and have just set it up in the last 20 mins. It sounds great and I now know why they say Saras need it. Right from the off it was tighter, faster and as I'm listening right now (Cream disraeli gears) It's improving by the minute. I've got all this to look forward to again on Wednesday as I'm picking up a 32.5 and hicap.
Yours in Music
Syd Big Grin Big Grin Big Grin
The system is still improving as the hours go by. Smile. How long before it is fully rerun in as it was last powered up on Wednesday when the seller tested it before packing it.
Also a big thank you to Richard Dane and Naim staff for the swift reply to my query as to the History of the unit. Serviced/Refurbed in July 97 so a good few years before it needs servicing again.
Yours in Music
Syd
Posted on: 20 January 2003 by David Patterson
Hi Syd,
By my powers of deduction that will be my 32.5 Hicap you be talking about.Just to let you know that they are being held at a constant 20degrees celcius and 55 % of relative humidity Big Grin
WinkHi David
Your correct, it's me. See you on Wednesday.
Yours in Music
Syd
