HDX streaming to XBOX with UPnP?
Posted by: RandyK on 15 August 2010
I thought this would just work, but alas it seems not. Is anyone successfully streaming from their HDX to an XBOX?
Thanks,
-randy
Posted on: 15 August 2010 by garyi
That might be the xbox which does not like a fair amount of file types.
Posted on: 16 August 2010 by Eloise
Does the XBox (I assume you mean XBox360) support UPnP, I thought it needed special Microsoft version?
Eloise
Posted on: 16 August 2010 by David Dever
Check via UPnP streaming software such as XBMC first–if you cannot get this to work, the problem likely lies within the XBox configuration itself.
Posted on: 16 August 2010 by garyi
I have tried XBOX with my upnp server(s) and it turned out to only like MP3, ymmv
Posted on: 16 August 2010 by mrspoon
The XBox will stream LPCM.
Posted on: 18 August 2010 by GerryMcg
I stream form Xbox360 to nDac with no problem. I use Windows Media Centre for music files on my Computer. I also stream from my NAS (via Jamcast software) for Spotify downloads, although this is done through the Virtual Soundcard facility of the Xbox, and not WMC.
