Naim Prefix
Posted by: Laurie Saunders on 07 November 2001
Hermann
I'm off to get my Prefix. I also use the Orbe/SME IV, did you have someone terminate the Prefix with the Din plugs for the SME V ? How do you connect it to the 52 (while I still look for a power supply), also through DINs ?
TIA
Does anybody use a supercap to individually power their prefix? I know this is pretty outrageous but is the difference obvious? If so then I assume this is a worthwhile upgrade in no compromise vinyl based system.
If anybody uses a supercap/prefix I would be very interested in a description of the performance benefits and how 'night and day' they are.
John
/Erik
Be warned though, doing this will compromise the 52 on all inputs not just Turntable and a Hicap is to be considered essential. (I appreciate the view on Supercapped prefix but £2300 is hefty wedge)
DMB
i agree...
enjoy
ken
Ulrich
BTW, Laurie, are you using the standard Helikon ? I found it to be a bit oppressive at loud volume, so I've ordered the low-output SL version ... looks like it's gonna be a long wait, though, as it's a limited edition and I guess they still have to make more stocks ...
Let me know what the outcome of your "adventure" is; best of luck -Laurie S.
Originally posted by Laurie Saunders:
By the way, if you are ordering a new prefix, you can specify the longer armlead and sme plug at the time of ordering. Naim will supply it that way. I purchased my prefix second hand, & sent it to Naim with the new armplug-they replaced the original short armlead and fixed the new plug.Once yo have it, it is less hassle to install it yourself than going to a dealer. The only fiddly part is inserting the new armplug into the base of the arm. This means slackening off the three armboard bolts to give you enough room to actually remomove and replace the plug. The whole installation took me about 15 minutes!
Laurie, I finally got and installed it yesterday, after some fiddling alright with the Michell's armboard, and readjusting VTA, etc. First impression - Super ! Definitely a no-brainer upgrade. This is the best phono stage I've ever tried on the Naim, and it's only Hi-Capped, now looking for a Supercap. All the superpatives regarding the Prefix are spot on ... I don't think any phono stage will be better for Naim, the Prefix just brings out the great Naim sound even more. Other phono stages bring out their own character ... And the Hicap, cables, Prefix aren't even warmed up yet the Naim way - at least a week !
Thanks to Paul Desmond, I had it pre-terminated with the SME DIN, excellent work. Didn't have the need to get a longer lead (may cause hum) ...
I was pleasantly surprised and pleased that it didn't look like the picture in Naim's website (see below), it actually is encased in a slim black box, pretty enough not to be hidden from view.
One query, the supplied cable from the Hicap to the 52 is colored gray. I was just wondering whether it really is gray or there is a better black version (4-pin to 5-pin). I tried to use a black Snaic, until I realized the Snaic had 5-pin to 5-pin, so I ust used the supplied gray cable ...
TIA ...
Originally posted by JosephR:
Laurie, I finally got and installed it yesterday, after some fiddling alright with the Michell's armboard, and readjusting VTA, etc. First impression - Super ! Definitely a no-brainer upgrade. This is the best phono stage I've ever tried on the Naim, and it's only Hi-Capped, now looking for a Supercap.TIA ...
Hi Joseph,
You know who to contact if you want to get rid of your Hi-Cap.
Thanks.
