ES14 users, please help……
Posted by: silklee on 11 September 2002
Dear ES14 users,
I recently got the ES14 with the original stands. But, sadly, the screws and spikes for the original stands are missing.
I managed to a shop that sells similar screws and spikes. However, there are 2 dimensions. One is 6 mm and the other is 8mm, known respectively as m6 and m8. Other than me bringing the stands down to the shop, could someone tell me the dimensions of the screws and spikes that I would need?
Thanks.
Posted on: 12 September 2002 by Matt worlock
Hey Silky I use ES!!/12 with dedicated stands mine are 8mm, yours are most likely the same but you could easily measure them yourself with a rular with millemeters on it & a set of calipers!!
wink
Mad Boy Matt
