Old Quadraphonic Vinyl Question
Posted by: Bob McC on 28 June 2002
I've got quite a few vinyl albums from the seventies encoded in SQ or QS. I've often wondered what might happen if this material was played into a modern AV surround amp what would happen in the decoding process. Has anyone ever done this and if so what did you notice?
Posted on: 28 June 2002 by garyi
More importantly, how the hell did it work? did you have two needles or something?
Sorry I wasn't even a glint when this stuff was out razz
Posted on: 28 June 2002 by Paul Ranson
The SQ and QS stuff are variations on a theme of matrix (I think slightly different implementations from CBS and Sony...). It's quite possible that pleasing results will come from a Dolby Pro-Logic type decoder.
JVC had something called 'CD4' which uses a sub-carrier to modulate the rear channels onto (akin to the way stereo FM works by broadcasting mono and a high frequency sub-carrier with the left/right difference signal) this will probably work with a modern MC but not with a general purpose AV decoder.
YMMV.
Paul
