NEAT ULTIMATUM MF9
Posted by: vimal on 11 November 2001
I have now had the Ultimatums in active mode for about 3 months,and it has been an experience,but also a little frustrating.
It was an experience because all the attributes you look for in going active was there,but a little frustrating, because there was one element that was difficult to get balanced and that was the bass.
I feel it could be the Naxo3-6 filter circuits that may require adjustment(not sure).As the Ultimatums are not true 3 way speakers but 2.5(two and a half),with the MF sharing the LF it was a little difficult to set the pots up for all music.I may have the Naxo modified while carrying out listening tests.I am certain this can be solved.They are still a superb listen if you are prepared to alter the setting to suit music type.
I have now received the passive crossovers from Bob Surgeoner of Neat Audio,they are encased in maple cabinets to match the sycamore speaker cabinets.Bobs cabinet maker must be a descendant of the strad violin maker, because these are beautifully finished.
I have had these hooked up passive for 5days,and they are back to what I remember when I decided to go for them.The bass seems to go even deeper than I remember and this could be due to the crossover now being external.I do miss the pin sharp imaging,and precision of the active set up.
In the next couple of weeks I will be hooking up
Alan Probin's Nap500 (very kind of Alan I just hope I dont get hooked on the 500 which could turn out costly).
In conclusion I was originally runnig active Isobariks with a sixpac, and was looking to replace the briks with a more modern speaker,
and I believe I have found them in the Neat Ultimatum MF9s.
