ProAc Saga - Part III
Posted by: Greg Beatty on 15 February 2002
I got my speakers back from the now-defunct ProAc dealer in Owings Mills Maryland. Following Richard Gerberg's advice, I removed the drivers and looked inside. He said to check the polarity of the wiring (ridged wire to pos on each driver) and to see if the larger driver was the specified 8 ohm or a daft replacement 14 ohm. My speakers are wired properly and have the specified 8 ohm drivers. So...
The nice folks at Soundworks in Kensington, Maryland let me borrow a listening room, a full Naim settup, and a pair of ProAc Response 1 SCs to use in checking out my ProAc Response 2's against a reference (the 1SCs). The naim kit on tap was a CD5/112/FC2/150 with NACA5. The system had been moved to a different room from last time.
To make a long story short, I no longer believe anything is wrong with my speakers(!). They sounded very similar to the 1SCs - easily bettering the 1's in scale and overall loudness with the 1's winning out by a small margin in the midrange. Good to know my speakers aren't knackered!!!
They are dang fine speakers and possibly *too good* for my current downgraded kit. These are not speakers that flatter a system that isn't up to snuff - no smoothed out highs and no bass boost. If it ain't there, you don't hear it.
I will probably advert these speakers on e-Bay or the local paper. Time for me to move on.
- Greg
Insert Witty Signature Line Here
