SBL's, bass, and the art of a NAXO
Posted by: Steve Hall on 06 February 2004
Having just for massive WAF points had wooden floors installed across the whole of the downstairs of the Chez Hall, I have been getting accustomed to the new sound of my system.
The sound from my CDS2/XPS1/52/SC/Naxo/Hi-Cap/180/180 -> SBL's (latest) system has obviously changed.
To recap, all components are supported on the best 2p's money can buy, the system itself is supported on two tiers of Quadraspire standard, mains is from a dedicated 10mm spur, MK unswitched logic socket into MusicWorks blocks and cables.
Even when the room was carpeted, the amount of base out of the system was nothing room shattering, however I described it as neutral and liked the sound. However with the floor changes, the system has become a little tizzy (eg Dreamland by Robert Plant - Funny In My Mind (I Believe I'm Fixin' To Die) ) after the initial keyboards is now uncomfortable to listen to at any volume (8pm is ok-ish, 9pm isnt).
I have placed a large rug between the speakers, and the seating position, and there is now only about .75m from speaker to start of rug, and .75m from end of rug to seating position - and the rug is the width of the speakers wide.
There are large, double lined curtains behind the seating position, and a large wall hanging behind the SBL's.
The SBL's are about 4cm (wood to wall - not metal stand) and have been recently resealed.
The only 'old' piece of kit in my setup is the 52, which is 9 years - and Naim themselves only suggest the front-panel mod to get the remote, switches and knobs updated.
What do you think could be sapping my bass? Do you think the NAXO (not S-NAXO) is out of kilter? Could the settings be making my SBL's to base light, or am I expecting to much?
