BasikPlus or Akito: To upgrade or not to ...
Posted by: Guido on 20 December 2001
There is a friendly offer of an Akito Tonearm - very reasonable priced. As I have a Basikplus arm here is my question:
Is the sonic difference between them noticeable?
As the Akito is quite reasonable priced this would be a nearly free upgrade, but: As the Basikplus was the predecessor of the Akito, is there enough difference to justify the hassle?
Thanks for your input!!
Guido
P.S.: Snow, snow and snow: white x-mas in munich!
I really like the sound of this combination and as the basikplus and the akito do look really similar (bearing seem identical) I was wondering if the akito was a "renamed" basik or a "redesigned" basik
Still wondering
Guido
TC '..'
"Girl, you thought he was a man, but he was a Muffin..."
My memory is that an akito came out after the ekos as linn had found ways of bringing some of the ekos ideas in at a greatly reduced cost. This is reflected in the arm tube design and the use of new (at the time) adhesives for bonding the head shell etc. I think the bearings are a step up from a basik also.
So if you don't want to spend a fortune I do think you would think this is a worthwhile upgrade. Get it fitted by a good dealer and make sure they are happy with the condition of the bearings etc
An Akito is a nice jump over an LVX, but I don't know about the Basik Plus. For a real upgrade, get an Ittok.
--Eric
Eric gave some excellent advice: check the bearings very carefully. I owned an early Akito and had no problems at all, but on about 1 in 3 the bearings could stick. If the bearings are perfect, the Akito represents a substantial upgrade from an Basik Plus--it is smoother, more detailed, more tuneful, etc. A K18 will sound A LOT better in an Akito. That said, a used Ittok LV2 is an even larger step up--when I upgraded from the Akito to the Ittok it was a bigger leap up than from Basik Plus to Akito.
On the other hand, since it is effectively free--don't hesitate if the bearings are good !
Bob
Can you stretch to a good Ittok (i.e. bearings)? Are you sure this is an Akito and not an Akito II?
And how are the bearings on your Basik+?
Phil
As used ittoks seem to be priced around 200 GBP (some less some more) - no additional funds available - has to wait for a while.
A side thought: I know myself; with an ittok I would try to go for a mid entry level mc cartridge - just to get the idea, as my k 18 might be insufficient for that arm, I have mm boards in the moment, so mc boards would be required, as the better arm and cartridge would justify improvement on the deck I might be tempted to search for a cirkus upgrade. Then I had to realize that interior mc boards are easily outperformed by, say a stageline - my psc used to power the stageline, a 2nd hand snaps bought (+ slic) to power the digital section of the 102, by this creating an imbalance with the ps of the lp12, searching for an appropriate ps - in the end thousands of pounds spend because I followed your advice to go for the ittok
I will check the bearings of the Akito (its a I) carefully - the ones of the basikplus are fine, did the bearing tests I read in another thread - as I'm quite new in the vinyl world (bought the deck in may and it took months to get all bits and pieces together) I want to move on slowly, yes my listening habits have changed - have not touched a cd for weeks (at home) - but lets see. My record collection has to catch up, too.
But I am convinced now - should go for the akito.
Btw. anyone looking for a immaculate basikplus?
regards
Guido
So upgrade the arm until you reach the top before considering upgrading the cartridge.
You also need to be looking at finding a Lingo or equivalent, the same principle applies.
Paul
Best regards,
Markus
