Tv through Naim System
Posted by: kev 1966 on 11 October 2009
Hi All,
A lit a help from all who have done this before, I have just set up my New Panasonic Tv.
I would like to have the option to have the audio through the hifi, Is it just putting a rca to din into the Tv out ?
All help appreciated
Kevin
Posted on: 11 October 2009 by james n
Thats the simplest option. You may need a ground loop isolator if you get hum.
Another way if the TV has a toslink output. Run it into a low cost DAC and then into the amp from their. No ground problems and better sound too.
James
Posted on: 11 October 2009 by mudwolf
yes RCA to DIN, I have a satellite box that I have the RCA to DIN. Also DVD player now has the last connection to DIN, I just hate the sound of the speakers on the TV being so vague, I seem to miss words. Could be my hearing going too, oh my! Roll Eyes
Posted on: 11 October 2009 by kev 1966
James
Hi James,
it say Digital audio out in the instructions is this what you mean?
Kevin
Yep - it should have an SPDIF digital output - normally toslink (optical)
James
James
James
I can't see ant reference to Toslink it's
a Panasoncic Tx-P42s10. Digital Audio Out Looks more like a pc type output
Kevin
Does it show a connection diagram showing if you can connect it an audio system - if it can then it'l;l either show RCA connections or am SPDIF connection. If it doesn't then you cant Smile
James
