Which Interconnect?
Posted by: gazla on 27 August 2007
I have my Nait5i connected to a Denon AV amp allowing the Nait to perform the l/r speaker duties . I am using a QED Qunex 2 interconnect at the moment but was wondering wether there were 'better' performing alternatives?
Posted on: 28 August 2007 by gazla
Apparently not then ... Smile
Posted on: 28 August 2007 by Steve S1
Gazla,
Welcome to the forum.
The QED is decent enough for what you are using it for. There is no limit to the amount you could spend on wanky wire but I'd forget it if I were you.
Steve
Thanks for the reply ... 'wanky wire' great product name maybe with a re-spelling ... 'wancki' ?
