How Much are chips
Posted by: woodface on 27 November 2003
Just want to know how much the 'chips' retail for?
Posted on: 27 November 2003 by syd
Our local has them for £1.00 a bag, lovely with salt and vinegar.
Yours in Music
Syd
Posted on: 27 November 2003 by GC
fifteen each....worth every penny though...
Posted on: 27 November 2003 by woodface
£15 each! So you are looking at £45 for the Fraim and £120 to do the speakers. Sorry but this is a ridiculous price.
Posted on: 27 November 2003 by John Sheridan
does anyone else find it odd that someone can spend £1000 (or more?) on a hi-fi stand and then say £15 for a fraim chip is ridiculous?
Posted on: 27 November 2003 by HTK
That's the price of a couple of CDs. So the question is, which will sound better?
Posted on: 27 November 2003 by J.N.
My dealer supplied me with a set of three; along with some other kit and they weren't itemised on the bill.
But; £12 for the three rings a bell?
Posted on: 27 November 2003 by Jonathan Hales
Yours in Music
Syd
Sorry Syd, but not to infer your joke was predictable, but there are as yet, undiscovered tribes in the heart of the Peruvian jungle that knew were going to say that.
Posted on: 28 November 2003 by woodface
That sounds ok, I know you may think I am being tight but spending money is one thing but getting ripped off is another.
Posted on: 28 November 2003 by Tristram
Having purchased a grand total of 14 chips, I can assure you that the money is well spent. I experimented with them under the NBL's first, which did seem to tighten up some of the presentation; then put them under both Fraim stacks. The results were nothing short of impressive.
I would strongly suggest you try them, particularly under a Fraim. They are tremendous; and considering some of the cable/conditioner/room reno's etc. that many propose here, they represent a relatively inexpensive way to "upgrade".
I would recommend a similar experiment: under the speakers, then the Fraim. tw
Posted on: 28 November 2003 by Geofiz
The chips are very very similar to an older product from the 80's marketed as "Tip Toes" which was a line of machined aluminium alloy cones (spikes) of various sizes and of similar cone with a dimple for use under the spikes to prevent damage to hardwood floors. If you can find any they will be cheaper than chips. If you are dubious about the effect that chips will have, try placing a coin (the 2 Euro coin would be good) under each spike. If you notice an improvement that you like, then going the extra step to the chips (or similar) will bring about a further improvement (and look better, your friends and guests when over will stop trying to pickup the coins
As I still have a quantity of the Tip Toes, that is what I have under all of my spiked stands which are on hardwood floors).
