New NAS or upgrade desktop PC?
Posted by: pixies on 29 April 2012
I currently have all my music, pictures and videos stored on a HP desktop (about 6/7 years old running XP with 1Tb storage). We all have laptops for daily use and the pc is really used as a source for streaming my music (FLAC via db poweramp, using squeezebox server). It’s left on 24/7,is a bit noisy and runs like a dog. However music is streamed to my Naim ND5XS very effectively.
I would like to get more out of streaming solutions and am investigating copying my DVD collection so I can do the same as I do with my music.
Have been checking out synology NAS solutions (DS 112j or DS212j). But before taking the plunge wonder whether I should just replace my desktop unit for a better more effective version (i.e. running windows 7, better RAM, bigger HD etc). Will both option offer same solutions?
Any advice is welcome.
There may be clues in the names:
Personal Computer
Network Attached Storage
Just a thought.
OK, but not so simple. I currently store lots of files and information on my computer, which I can also share/stream to devices around the house (I have a separate back up hard drive), so computer = computer and storage.
If you are happy to keep your computer on all the time, then you can continue to do so.
I now have our PCs & MACs connected to a NAS drive either via CAT6a cable or wifi at home and every computer has full access to the music, photos, videos etc that are on the NAS drive.
There is then always the option of using a computer to backup the information on the NAS drive, though I have a 2nd NAS drive located remotely, which runs nightly backups (in case the first drive dies or is lost/stolen).
The NAS drive is really quiet and MUCH more energy efficient than running our PCs 24/7.
So, I've chosen the NAS route, though this does cost more, which can also be an important factor in the real world.
Hope this helps, FT
I'd move everything you want to share onto a NAS, then everything FT says is right... simple
(really)
I agree with a FT, a little NAS is/should be more energy efficient than a PC/Mac server and be smaller and more quiet. My PCs and Mac sleep when not in use, but my NAS stays on always.
Simon
OK thanks for the comments. I had pretty much decided the NAS route for all the reasons you have outlined above, but hesitated a little a the last step hence my original question.
Sorry to insert something new, but someone will speak up for Vortexbox so might's well be me. Stores, serves and rips all in one nice package, including DVDs. You can convert your old computer into one (though not power efficient) or buy a very efficient one new for not much more than a decent NAS. I've been very frustrated with the operating systems and "dashboards" on various NASs. But, the vortexbox works great all the time.
Vortexbox looks a useful bit of kit, but could I justify it when I can rip from my hdx? I would use mainly for storing hi-res downloads
I am using a QNAP NAS (Raid 1 config) mainly because I do not want to leave my computer on 24/7. The QNAP works great, but if you have an extensive classical music library, you may find QNAP's Twonky server music tree rather limited. From time to time I will have to turn on the PC (connected to NAS) and use Asset to find a particular piece of classical music. For other kinds of music Twonky is fine.
I have no knowledge on Synology NAS though.
How quiet is the HP ProLiant?. Thanks!
Hi McGie. Your suggestions are very interesting and there are still cashback deals on this. However I am no expert on these things. could you just explain your set up and how it works. Do I still keep my existing desktop? What is a headless server?
Thanks Ian for taking the time to explain. I will do a bit more research on this, armed with the advise you have given.
Vortexbox is great in my set-up, but it is a full fledged music server. I have no Windows computers on my network, but I don't see why it wouldn't work with them if you did, however, I can't vouch for that personally. For me it does everything I could want from a UPnP server and it works seamlessly with my Apple kit and being Linux it is fairly bullet proof. I know Asset has more features, but it is a non-starter for me unless there is a Linux or OS X port, but even then I'll probably stay with the VB - not sure if Asset supports DAAP, which I use on occasions. And as my Vortexbox music server just works might as well keep it going.
I'm not sure you would use all its facilities with the HDX, but as VB free - you could try it and see.
[The Mac Mini as a player in to the Naim DAC is pretty faultless, at least it has been for me. However, it would replace rather than work with the HDX, which is not what you'd want - no advantage in doing that as far as I can see - except for the MM's ability to store downloads, which is probably of no consequence].
Just an update following my original post and the many useful suggestions.
I have gone the NAS route and have just installed a Synology DS212J with 2TB HDD. Initial set up has been a bit challenging but I now have Logitech Media Server installed to serve my ND5xs and squeezebox players and responsiveness is much improved. All family laptops are connected to use the central printer, and I can stream my videos to the TV via its media server. I know it can do much more but early days. Main noisy PC can now be turned off and used for back up and ad hoc purposes. The NAS is very efficient and quiet and also cost a lot less than buying a new PC. So happy days ![]()
Cheers!
