Duplicate Album Title...
Posted by: solaay47 on 29 April 2012
Hi, apologies if this questiion has been asked before but what tags am I missing as when I view by albums on the n stream app the album title appears twice?
Any advice welcomed, thanks
Posted on: 30 April 2012 by Manu
It depends on the UPnP server you are using.
Posted on: 30 April 2012 by Nagoya
You should have a look at your tags with your tagging software.Thanks!.
Posted on: 02 May 2012 by Damon
Not sure if I will be helpful, but I find that duplicate albums seem to be seen in N-stream when there is differing meta data. I think this is what Nagoya is referring to with the term 'tags'.
So if you have several songs by an artist, and one song has a different author, or some other differing piece of information in the database of information about that song, N-Stream shows it as a different album. If a song has no album name, it shows as a different album.
For me, it tends to be an issue with songs collected individually, or with my music that I've recorded myself.
I'm using iTunes, Playback and a UnitiQute.
Posted on: 04 May 2012 by solaay47
Hi, I'll look at the tags this weekend. Thanks
