Transcode FLAC to WAV in Asset or "as is"
Posted by: Thorsten_L on 02 May 2012
Hi there!
What is better: To let Asset transcode the FLAC-file on my PC to WAV or stream it in Asset as a FLAC, using the default "FLAC as is" replay?
When I check FLAC as WAV, the ND5Xs shows in the info the file as WAV...
Posted on: 02 May 2012 by Simon-in-Suffolk
Hi - whatever sounds best to you. I personally let Asset transcode flac to wav. as I prefer the way wav sounds, but there are others on this forum that hear no difference. Fortunately on Asset it is a simple click of the mouse to change one way or other as you have probably found.
Simon
Posted on: 02 May 2012 by Hook
Hi Thorsten-
I have Asset do the conversion, even though I do not hear a difference (but I understand why, in theory, others may).  The advantage I gain is that my non-FLAC compatible devices - my AVR and my Apple devices running Plugplayer - can share Asset's UPnP service.
Good luck!
Hook
PS - First ever post from iPhone, so hopefully reads ok!
Posted on: 02 May 2012 by Guido Fawkes
If it can why not - it certainly won't sound worse and some devices may sound better - although I can hear no difference in my set-up if it were an option on the Vortexbox then I'd still switch it on.
Posted on: 02 May 2012 by Thorsten_L
Thank you.
I will let Asset do the work.
Posted on: 03 May 2012 by Tog
I have no issues streaming flac from Vortexbox to Plugplayer on my iPad!
The Vortexbox guys have been asked about transcoding flac to wav but they seem to find the idea awfully amusing and utterly pointless ....
Tog
