Unable to update Unitiserve SSD to 1.6c
Posted by: The Meerkat on 05 May 2012
I have burnt a disc using 'Disc Utility' on my iMac. The disc that I have created is 1.6c Software Updater.iso. I have mirrored the instructions given on 'iClarified', "How to burn an iso Disc image using Mac osx".
After burning the disc, I re-inserted the disc into the computer to check the contents. The disc shows three folders. 'Desktop Client', 'Manuals' and 'Upgrade'.
When the 'Upgrade' folder is opened, it displays five zip files/folders. NS01, NS02, NS03, NSHDX and NSSRV Upgrade v1.6c. As far as I am aware, this indicates that I have burnt the disc correctly.
I then inserted the disc into the Unitiserve SSD, which then sounds like it is reading the disc. However, the disc is ejected after only about 10-12 seconds. I have tried this several times and also burnt a new disc in case the other was faulty. I have also shut down the unit and turned it back on again.
On checking 'System Settings' in the browser interface, it still shows 1.6b.
Before I call the 'Hot Line' on Tuesday, can anyone tell me what I may be doing wrong please.
